I recently managed a rudimentary data transfer via Xbees, although with a hiccup here and there.
I transmitted 0xAA, a nice output stayed at the receiver via PORTD connected to eight LEDs.
But when I transmitted 0xBB, the receiver (LEDs lighting up) initially shows the data correctly for a few seconds, then somehow flickered and all the LEDs light up without responding to further transmission. It's like a "computer hang".
Anyway, here's the code (Transmitter: 16F877A, connected to a keypad, the polling is for the keypad switch)
C:
while (1){
if (rd3_bit==1 && trmt_bit==1){
txreg=0xaa;
if (rd2_bit==1 && trmt_bit==1){
txreg=0xbb
And here's the Receiver (18F4620, output at PORTD):
I am writing some code to "Manchester encode" the data before it is sent via RS232 and re-assemble at the other end... It's kinda finished... It works ok but when you use 0xAA for preamble its the same as "0" encoded... just needs a little work..... Do you want a "look see"
Most possibly.... I use XRF modules (xbee format) and I get real good quality signals... I tend to go for 19200 baud.. I do get errors when I go at 115200..
I agree with Nigel. The data should be sent in packets complete with error checking. Any corrupted data is NAKed by the receiver and resent. You fellows are talking like you are using raw radio ?
No... I use packets and CRC's just like everyone else.. Start sequence.... data length... data... crc... Just a basic crc though.. I suspect Nigel's right about the OP not setting the modules up correctly.
If think you're missing the point?, why do you have to do that? - isn't Xbee an 'intelligent' system, and does all that for you, you just need to supply raw RS232 data.
I've never had any to play with, so I can't be sure - but I thought that was the idea of Xbee?.
I don't use xbee.. I use XRF modules.. The OP uses Xbee... I have used xbee in the past BUT there are two modes....AT mode where you must take the raw data approach and the API mode where the data is in a packet, and on a multi module net... the user must select the mode with the X-CTU program.
I also use XRF modules, i find them a lot easier to use than the Xbee, so far i have no problems sending packets or raw data back and forth. maybe the Xbee is missing the data being sent somehow, the OP says its like a computer hang. If its missing data then it wouldnt get the whole command.
From the XBee manual:
By default, the RF module operates in Unicast Mode. Unicast Mode is the only mode that supports
retries. While in this mode, receiving modules send an ACK (acknowledgement) of RF packet
reception to the transmitter. If the transmitting module does not receive the ACK, it will re-send
the packet up to three times or until the ACK is received.
You are thinking wrong. Xbee has several modes. If you are doing peer to peer, default mode perhaps, what you put in one Xbee magically pops out the other.
But there is a lot more then a simple radio connection. It takes your data and encodes it and then decodes it on the other end.
All you have to do is provide raw data. Do not use manchester, error correction or packets in your micro controller code. Xbee does that for you.
Alright man. Thanks for your info. The Manchester thingy sounds pretty "value addition-like" kinda thing... but oh well since you suggest I drop it. Anyway, it seems that the fluctuating power supply I made myself is probably the cause. Everything works fine now, Thank God.
Now I'm gonna do some data logging with these. Will come back soon if I have anything else.
One thing I have noticed, is that you have no apparent de-bouncing on your input keys (unless you have done so in hardware with an RC and a 7414 or something).
Also I thought Xbee as already stated handles all the error correction and resending for you in the default peer to peer mode.
