how to give 120degree phase shift i've written a code
esconele
whats wrong in my code because all pins showing pulse at same time meance there is no phase shift even if i 've given that much delay and toggle next pin after that where i'm doing wrong pls tell me
	#include "p18f458.inc"
;------------------BIT DEFINITIONS------------------------------------
F                 EQU      0x0001
;COUNT1 EQU 200
;COUNT2 EQU 0x0003
;COUNT3 EQU 0x0004
red equ B'10101010'
green equ B'01010101'
var UDATA
COUNT1 res 1
COUNT2 res 1
COUNT3 res 1
COUNT4 res 1
temp_1 res 1
temp_2 res 1
temp_3 res 1
;------------------VECTORS--------------------------------------------
	org	0x000000		; reset vector
	bra	START
	org	0x000008		; high priority interrupt vector
	bra	TMR3_ISR
	org 0x000070
;--------------------PROGRAM-----------------------------------
START
	clrf LATD
  	rcall    INIT
;Set up priority interrupts.
	bsf	RCON,IPEN	;enable priority interrupts.
	bsf	IPR2,TMR3IP	;set Timer3 as a low priority interrupt source
	bcf	PIR2,TMR3IF	;clear the Timer3 interrupt flag
	bsf	PIE2,TMR3IE	;enable Timer3 interrupts
	bsf	INTCON,GIEH	;set the global interrupt enable bits
	bsf	INTCON,GIEL	;	"
	MOVLW 0X02
	MOVWF temp_1
	clrf	T3CON
	bsf	T3CON,TMR3ON	;turn on Timer3
	movlw	0xd0
	movwf	TMR3H		;write 0xf000 to Timer3
	clrf	TMR3L
	movlw 0x01
	movwf COUNT4
MLOOP
	goto	MLOOP
;-------------------------------SUBROUTINES---------------------------------
TMR3_ISR			;low priority isr
	CPFSEQ COUNT4
LP1  goto lpl
LP2
	BTG LATD,7
	BTG LATD,6
	movlw 0x02
	movwf COUNT1
	movwf COUNT2
	movlw 0x01
	movwf COUNT3
	bcf	PIR1,TMR1IF	;Clear the Timer1 interrupt flag.
lppl
	movlw 0xff
	movwf TMR3H
	movlw 0xfe
	movwf TMR3L
T1POLLl
	btfss	PIR2,TMR3IF	;Poll TMR11 interrupt flag to wait for another
				; TMR1 overflow.
	bra	T1POLLl
	movlw 0xff
	movwf TMR3H
	movlw 0xfe
	movwf TMR3L
	bcf	PIR2,TMR3IF	;Clear the Timer1 interrupt flag again.
	decfsz COUNT1,F
	bra lppl
	decfsz COUNT2,F
	bra lppl
	decfsz COUNT3,F
	bra lppl
	INCF COUNT4
	MOVLW 0X02
	CPFSEQ COUNT4
LPP1
		goto lpl
LPP2
	bcf	PIR2,TMR3IF	;Clear the TMR3 interrupt flag.
	movlw 0xd0
	movwf TMR3H
	movlw 0x00
	movwf TMR3L
T1POLLl1
				; TMR1 overflow.
	bra	T1POLLl1
	DECF COUNT4
	GOTO LP3
LP3
	BTG LATD,5
	BTG LATD,4
	movlw	0xd0
	MOVLW 0X01
	clrf	TMR3L
	;GOTO LP2
lpl
	retfie
INIT
	movlw red
	movwf LATD
   	 clrf	LATC		; setup portb for outputs
	clrf	TRISC
	clrf	TRISD
	return
	END
Now that you have presented code in the proper manner, could you give some more info? Which pins have to be 120 degrees delayed w.r.t each other? Try to give as much info as possible so we don't have waste time trying to decrypt your code.
Help us to help you.
HOW TO GIVE 120 DEGREE PHASE SHIFT
sir,
thanks for replying me actually i want a phase shift of 120degree in between PORTD7 and PORTD5 and again 120degree phase shift in between PORTD5,and PORTC7 these pins will be high first and at the same time PORTD6,PORTD,4 and PORTC,6 will be low having 120degree phase shift in between them this will be like this
R=PORTD,7
~R=PORTD,6
y=PORTD,5
~Y=PORTD,4
B=PORTC,7
~B=PORTC,6
WITH 120DEGREE PHASE SHIFT IN BETWEEN R-Y-B AND SAME FOR ~R-~Y-~B
CAN I CALL A DELAY(FOR PHASE SHIFT) ROUTINE IN ISR ROUTINE AND AT THE SAME TIME I WANT A PULSE OF 50HZ ON EACH PIN I'M USING A CRYSTAL OF 4.9152MHZ FOR THAT DID I CALCULATED THE CORRECT VALUES AND IS IT NECESSORY TO LOAD 0X07 IN CMCON REGISTER TO INITIALIZE PORTD BECAUSE IF I GIVE LOW INPUT TO PINS PORTD,6,4 AND PORTC,6 THEN THESE PINS REMAINS LOW AT ALL TIME AND EVEN IF I TOGGLED THE PORTD,5 AND PORTC,7 PIN AFTER PHASE SHIFT DELAY THEN ALSO THESE PINS STARTS TOGGLING AT THE SAME TIME AS PORTD,7 PIN TOGGLES HWERE I'M DOING WRONG SIR
I haven't had time to go through you code because frankly it looks like a mess! It looks like you have a delay loop within the ISR.
Anyway as suspected, you are trying to make a 3-phase inverter, possibly a motor inverter.
The way I would approach is to use a lookup table to index through. During a periodic interrupt, you take the values from this lookup table, indexing one step at each interrupt, and output them at the corresponding pins. At the end of the table, you start from the beginning on the next interrupt. Since you want to output 50Hz square wave, you need to interrupt at 6X this rate or 300Hz.
The table values will be as follows:
 retlw b'10010100'
 retlw b'10100100'
 retlw b'10101000'
 retlw b'01101000'
 retlw b'01011000'
 retlw b'01010100'
BTW, from the table RYB are displaced by 30degress from each other. However, their R and ~Y are displaced by 120 degrees. Just tweak the table to get the desired results.
HTH
hello sir,
i tried whatever you told me in prev reply and it was working but there was pulses only on portd 7 5 and portc,7 pins and there was more fluctuation in pulses thatswhy i again tried this code,
this code is giving the results whatever i want but there is some dropping of pulse after each 3 or 4 second why this is hapning and is this correct code for interfacing 3-phase 50hz power supply (120degree phase shift ) with pic18f458
and how to remove that dropping fault thanks
F EQU 0x0001
;COUNT1 EQU 200
;COUNT2 EQU 0x0003
;COUNT3 EQU 0x0004
red equ B'10101010'
var UDATA
COUNT1 res 1
COUNT2 res 1
COUNT3 res 1
COUNT4 res 1
temp_1 res 1
temp_2 res 1
temp_3 res 1
bra START
bra TMR3_ISR
org 0x000070
START
rcall INIT
bsf INTCON,GIEL ; "
MOVLW 0X02
MOVWF temp_1
clrf T3CON
movlw 0xd0
clrf TMR3L
movlw 0x01
movwf COUNT4
MLOOP
goto MLOOP
CPFSEQ COUNT4
LP1 goto lpl
LP2
BTG LATD,7
BTG LATD,6
rcall delay240
incf COUNT4
MOVLW 0X02
CPFSEQ COUNT4
LPP1
goto lpl
LPP2
incf COUNT4
GOTO LP3
LP3
BTG LATD,5
BTG LATD,4
rcall delay120
movlw 0x03
cpfseq COUNT4
lp4
  bra lpl
lp5
btg LATC,7
btg LATC,6
decf COUNT4
decf COUNT4
lp6
  movlw 0xd0
  movwf TMR3H
clrf TMR3L
lpl
retfie
INIT
clrf LATD
movlw red
movwf LATD
clrf PORTC
clrf TRISD
clrf TRISC
bsf LATC,7
bcf LATC,6
return
delay240
timer3 delay for .763sec
return
delay120
timer3 delay for .381sec
return
END
It's hard to tell the cause of this if you don't post the code. You should have put all phase outputs into one port.
This could be a watchdog timer timeout. I don't see any configuration fuse directive in your code.
hello sir,
here is the code which is giving me correct output only when i give support to ckt and i diasabled the watchdog timer also
F EQU 0x0001
;COUNT1 EQU 200
;COUNT2 EQU 0x0003
;COUNT3 EQU 0x0004
red equ B'10101010'
var UDATA
COUNT1 res 1
COUNT2 res 1
COUNT3 res 1
COUNT4 res 1
temp_1 res 1
temp_2 res 1
temp_3 res 1
bra START
bra TMR3_ISR
org 0x000070
START
rcall INIT
bsf INTCON,GIEL ; "
clrf T3CON
movlw 0xd0
clrf TMR3L
movlw 0x01
movwf COUNT4
MLOOP
goto MLOOP
CPFSEQ COUNT4
LP1 goto lpl
LP2
BTG LATD,7
BTG LATD,6
rcall delay240
incf COUNT4
MOVLW 0X02
CPFSEQ COUNT4
LPP1
goto lpl
LPP2
incf COUNT4
GOTO LP3
LP3
BTG LATD,5
BTG LATD,4
rcall delay120
movlw 0x03
cpfseq COUNT4
lp4
  bra lpl
lp5
btg LATD,3
btg LATD,2
decf COUNT4
decf COUNT4
lp6
  movlw 0xd0
  movwf TMR3H
clrf TMR3L
lpl
retfie
INIT
clrf PORTD
clrf LATD
movlw red
movwf LATD
clrf TRISD
return
delay240
movlw D'200'
movwf COUNT1
movlw D'2'
movwf COUNT2
halt1:
decfsz COUNT1,1
goto halt1
decfsz COUNT2,1
goto halt1
 movlw 0xd0
  movwf TMR3H
clrf TMR3L
bsf T3CON,TMR3ON
return
delay120
movlw D'200'
movwf COUNT1
halt12:
decfsz COUNT1,1
goto halt12
 movlw 0xd0
  movwf TMR3H
clrf TMR3L
bsf T3CON,TMR3ON
return
END
You have to disable the watchdog timer. Because if you do not disable (enable) the watchdog timer then you have to add the instruction "clrwdt" within the program loop. Without this instruction, your PIC will reset on watchdog timeout. I scanned your code and I don't see any clrwdt instruction.
its working thank you
sir,
finally its working i disabled watchdog timer , enabled power up timer ,disabled brown out detect , disabled ccp2 mux , disabled low voltage prog, and finally its giving the correct results but you told that we can't call delay routine in ISR routine then is my code wrong ? and then how to phase shift delay without delay routine ?you helped me a lot and thnks a lot fot that.
As motion said, you need to interrupt at 6 times your frequency. 6*50Hz = 300Hz. You need to set your timer so it interrupts every 3.3mS. You then set the outputs from values that are in a table.
Alternatively, you can rotate a variable to generate the necessary outputs.
; initialise the variable to have 3 bits set.
                movlw   b'00111000'
                movwf   Phase
; in your ISR rotate the variable like this.
                rrf     Phase,F
                bcf     Phase,7
                btfsc   STATUS,C
                bsf     Phase,5
After the above shift, bit 5 will be the red phase, bit 3 will be blue and bit 1 will be yellow.
HTH
thank you sir,
i tried whatever you told its working now problem is that for next 3 second i want just reverse that of first according to your sugg. pins 5 and 2 ,pins 4 and 1, pins 3 and 0 was exactely reverse can i use the same data meance can i use pin 2 values for pin 5 to get reverse of first.
pls help me thank you.
how to give deadband
thank you sir for replying me ,
actually when i swaped two phases like i'm using portd 5,4,3,2,1,0 pins and for that 5 is red ,3 is blue and 1 yellow and 2 is compliment of 5, 0 is of 3 and 4 is of 1 now when i want reverse motivation of motor then i want pulse of 2 on 5 and 0 on 3 and 4 on 1 and viceversa in first cycle we were passing 00111000 and for 6 intrruption cycle pulse was coming correctely but for next reverse cycle when i swap 2 phases then i've to pass 00110010 isn't it but for that pulses was not coming correctely and duty cycle was not 50% then what i done is i've taken the values for 6 intruption and swap these values for the respective pins by updating a flag and its giving the results but is this a right way and one more thing is that now i want to give 5microsecond delay in between top and bottom meance in between R and ~R , y and ~y , b and ~b how can it be possible waiting for reply thank you.
Re: how to give deadband
;PROJECT NAME::ARD INVERTER
; FILENAME:1912.asm(main)
; RELETED FILES:BCD.asm,p2plsp18.lkr
;3-PHASE 50Hz SUPPLY TO PORT  D WITH 120 DEG. PHASE SHIFT
;PORTD.5-R,PORTD.2- ~R
;PORTD.3-B,PORTD.0- ~B
;PORTD.1-Y,PORTD.4- ~Y
;FOR FIRST 3 SEC MOTOR SHOULD RUN IN ONE DIRECTION
;AFTER 1 SEC HALT AGAIN FOR NEXT 3-SEC MOTOR SHOULD RUN IN REVERSE DIRECTION
;IN BETWEEN THIS CHECK THE VTG OF EACH DIRECTION WITH ADC
;COMPARE THE VTGS OF 2 MODES RUN THAT MODE WHICH HAS LOW VTG CONTINUOUSLY
;DATE:21/12/05
;	list P = 18C452
	#include "P18F452.inc"
; DECLARATION OF REGISTERS
TENMSH EQU 50
TENMSL EQU 243
RED EQU B'10101010'
phase equ B'00111000'
revphase equ B'00000111'
F     EQU      0x0001
VARIEBALS UDATA
COUNT1   RES 1
COUNT2   RES 1
T2       RES 1
t1       RES 1
#define	_C	STATUS,0
	org 0x000000
	goto START
	org 0x000008
	bra INT0ISR
	org 0x00000526
START
	rcall    INIT
	bSf	INTCON,GIEH	;set the global interrupt enable bits
	bSf	INTCON,GIEL	;	"
	BSF INTCON,INT0IE
	BCF INTCON,INT0IF	;SET INT0 INTRUPT ON LOW EDGE
	BCF INTCON2,INTEDG0
	btfsc PORTC,6
rt1:
	bra $-2
rt2:
	rcall sample
	rcall DELAY3sec
	rcall DELAY1sec
	rcall sample1
	rcall DELAYrev3sec
	rcall DELAY1sec
loop0
	rcall VOLTAGE_C
	GOTO loop0
INIT:
	setf	PORTD
	setf    LATD				;setup portd for outputs
	movlw   0x00
	movwf	TRISD
	setf	PORTC				;setup portc for outputs
	setf	LATC
	movlw   0x00
	movwf 	TRISC
	setf	PORTB
	setf    LATB				;setup portd for outputs
	movlw   0x00
	movwf	TRISB
	clrf t1
	MOVLW 0X04
	MOVWF T2
	return
INT0ISR
	setf PORTD
	SETF LATD
	clrf TRISD
	bcf PORTC,6
	retfie
;INTIALISATION OF PORT PINS IN NORMAL MODE
sample:
	BCF PORTC,7
	clrf LATD
	clrf PORTD
	clrf TRISD
	movlw phase
	movwf PORTD
	return
;PORT PINS IN REVERSE MODE
sample1:
	clrf LATD
	clrf PORTD
	clrf TRISD
	movlw revphase
	movwf PORTD
	return
delay5us:
	movlw	0xFF		;Load TMR3 with the value 0xF000
	movwf	TMR3H
	movlw  0xFC
	movwf	TMR3L
	bSf	T3CON,TMR3ON	;Clear the Timer3 interrupt flag again.
T3POLL
	btfss	PIR2,TMR3IF	;Poll TMR3 interrupt flag to wait for another TMR3 overflow.
	bra	T3POLL
	bcf	T3CON,TMR3ON	;Clear the Timer3 interrupt flag again.
	bcf	PIR2,TMR3IF	    ;Clear the Timer3 interrupt flag again.
	return
DELAY1sec:
	movlw D'255'
	movwf COUNT1
	MOVLW 0X06
	MOVWF COUNT2
sec1:	movlw	0xF2		;Load TMR3 with the value 0xF2FA
	movwf	TMR3H
	movlw  0xFA
	movwf	TMR3L
T3POLL1
	bra	T3POLL1
	decfsz COUNT1,1
	goto sec1
	decfsz COUNT2,1
	GOTO 	sec1
	return
;DELAY FOR WHICH TWO MODES SHOULD BE RUN
DELAY3sec:
	movlw D'200'
	movwf COUNT1
	MOVLW 0X02
	MOVWF	COUNT2
sec3:	movlw	0xD8		;Load TMR3 with the value 0xD8F0
	movwf	TMR3H
	movlw  0xF0
	movwf	TMR3L
T3POLL3
	bra	T3POLL3
	rcall TENMS
	rcall ADC
	decfsz COUNT1,1
	goto sec3
	DECFSZ COUNT2,1
	GOTO sec3
	btg PORTC,5
	movf temp_1,W
	movwf comp_0
	movf temp_3,W
	movwf comp_4
	movf temp_4,W
	movwf comp_5
	return
DELAYrev3sec:
	movlw D'200'
	movwf COUNT1
	MOVLW 0x02
	MOVWF COUNT2
rsec3:	movlw	0xD8		;Load TMR3 with the value 0xD8F0
	movwf	TMR3H
	movlw  0xF0
	movwf	TMR3L
T3POL3
	bra	T3POL3
	rcall TENMSre
	rcall ADCc
	decfsz COUNT1,1
	goto rsec3
	DECFSZ COUNT2,1
	GOTO rsec3
	btg PORTC,4
	movf temp_1,W
	movwf comp_1
	movf temp_3,W
	movwf comp_2
	movf temp_4,W
	movwf comp_3
	return
;5HZ FREQ ROUTINE FOR FIRST 3 SEC ONE DIRECTION
TENMS
	MOVLW TENMSH
	MOVWF COUNTH
	MOVLW TENMSL
	MOVWF COUNTL
TEN1
	DECFSZ COUNTL,F
	GOTO TEN1
	DECFSZ COUNTH,F
	GOTO TEN1
	rrcf    PORTD,F
    bcf     PORTD,7
    btfsc   STATUS,C
    bsf     PORTD,5
TENMSEND
	return
;5HZ FREQ ROUTINE FOR NEXT 3 SEC REVERSE DIRECTION
TENMSre
	MOVLW TENMSH
	MOVWF COUNTH
	MOVLW TENMSL
	MOVWF COUNTL
TEN1re
	DECFSZ COUNTL,F
	GOTO TEN1re
	DECFSZ COUNTH,F
	GOTO TEN1re
	incf t1
	MOVLW 0X01
	CPFSGT T2
O1
	GOTO O2
O3
	rrcf    PORTD,F
    bcf     PORTD,7
    btfsc   STATUS,C
    bsf     PORTD,5
	DECF T2
O2
	movlw 0x04
	cpfseq t1
pl1
	goto l3
pl2
	movlw 0x18
	movwf PORTD
	incf t1
	CLRF T2
l3
	movlw 0x05
	cpfseq t1
l4
	goto l5
l6
	movlw 0x1c
	movwf PORTD
l5
	movlw 0x06
	cpfseq t1
l7
	goto l8
l9
	movlw 0x0A
	movwf PORTD
	INCF t1
l8
	movlw 0x07
	cpfseq t1
l10
	goto pl10
l11
	movlw 0x0A
	movwf PORTD
	INCF t1
pl10
	movlw 0x08
	cpfseq t1
l12
	goto l13
l14
	movlw 0x0e
	movwf PORTD
l13
	movlw 0x09
	cpfseq t1
l15
	goto l16
l17
	movlw 0x03
	movwf PORTD
	INCF t1
l16
	movlw 0x0a
	cpfseq t1
l18
	goto l19
l20
	movlw 0x03
	movwf PORTD
	INCF t1
l19
	movlw 0x0b
	cpfseq t1
l21
	goto l22
l23
	movlw 0x07
	movwf PORTD
	movlw 0x01
	movwf t1
	MOVLW 0X04
	MOVWF T2
l22
TENMSreEND
	RETURN
     END
hello sir,
first thank you for replying and helping me now its working but now problem is that i want to give 5microsecond delay in betwen top and bottom i.e dead band in between R and ~R and others also how i can achieve this waiting for reply thank you .
50hz PWM pulse
hello sir,
i'm using 18f4431 for my project for that crystal used is 4.9152Mhz and i want 0.1 to 50hz PWM can it be possible with this because we have to load value only in PR2 and calculated value for 50hz is 5fff how can i achieve this
thank you.
hello everyone,
here i'm using 18f452 i want 6 output pulses with 50hz like R, ~R,Y,~Y ,B,~B AND 120DEGREE PHASE SHIFT IN BETWEEN R-Y-B,~R-~Y-~B AND 5MICROSECOND DEADBAND IN BETWEEN R & ~R,Y & ~Y AND B & ~B I'VE WRITTEN A CODE WHICH GIVES ME DEADBAND OF 5 MICROSEC BUT PHASE SHIFT IS ONLY 30DEGREE HOW COULD I AHEIVE 120DEGREE PHASE SHIFT AND ALL REMAINING THINGS TOGETHER ACTUALLY I TRIED WITH ROTATING PORT AND IT WAS GIVING 120 DEGREE PHASE SHIFT BUT IN THAT CASE DEADBAND WAS NOT POSSIBLE AND DEADBAND IS MUST PLS HELP ME .
THANK YOU
#include "p18f452.inc"
F EQU 0x0001
;COUNT1 EQU 200
;COUNT2 EQU 0x0003
;COUNT3 EQU 0x0004
red equ B'00101010'
var UDATA
COUNT1 res 1
COUNT2 res 1
COUNT3 res 1
COUNT4 res 1
temp_1 res 1
temp_2 res 1
temp_3 res 1
bra START
bra TMR3_ISR
org 0x000070
START
rcall INIT
bsf IPR2,TMR3IP ;set Timer3 as a high priority interrupt source
bsf INTCON,GIEL ; "
MOVLW 0X02
MOVWF temp_1
clrf T3CON
movlw 0xd0
movwf TMR3H ;write 0xd000 to Timer3
clrf TMR3L
movlw 0x01
movwf COUNT4
MLOOP
goto MLOOP
TMR3_ISR ;high priority isr
CPFSEQ COUNT4
LP1 goto lpl
LP2
BTG PORTD,5
nop
nop
nop
nop
nop
BTG PORTD,2
incf COUNT4
MOVLW 0X02
CPFSEQ COUNT4
LPP1
goto lpl
LPP2
incf COUNT4
GOTO LP3
LP3
BTG PORTD,1
nop
nop
nop
nop
nop
BTG PORTD,4
movlw 0x03
cpfseq COUNT4
lp4
  bra lpl
lp5
btg PORTD,3
nop
nop
nop
nop
nop
btg PORTD,0
decf COUNT4
decf COUNT4
lp6
  movlw 0xd0
  movwf TMR3H
clrf TMR3L
lpl
retfie
INIT
clrf PORTD
clrf LATD
clrf TRISD
movlw red
movwf LATD
return
END
esconele said:
hello everyone,
CPFSEQ COUNT4
LP1 goto lpl
Your code is very hard to follow, the code above seems to have a goto itself instruction. You should repost your code using the code tag. You should also ensure that the code that you post is case readable. I.E. if you have goto lp1, you should not have a similar label called lpl.
PHASE SHIFT OF 120
HELLO,
HERE I'VE POSTED MY CODE PLS GIVE ME THE CLUE HOW TO GIVE 120 DEGREE PHASE SHIFT IN BETWEEN R-Y-B AND 5microsec DEAD BAND IN BETWEEN R - ~R ,Y - ~Y,B - ~B WITH 50HZ FREQ ON EACH OUTPUT PIN
THANK YOU
F EQU 0x0001
red equ B'00101010'
var    UDATA
COUNT1 res 1
COUNT2 res 1
COUNT3 res 1
COUNT4 res 1
temp_1 res 1
temp_2 res 1
temp_3 res 1
bra START
bra TMR3_ISR
org 0x000070
START
rcall INIT
bsf INTCON,GIEL
MOVLW 0X02
MOVWF temp_1
clrf T3CON
movlw 0xd0
clrf TMR3L
movlw 0x01
movwf COUNT4
MLOOP
      goto MLOOP
CPFSEQ COUNT4
LP1:
	goto LPLAST
LP2:
	BTG PORTD,5 	;toggle R
	nop 		;5microsec delay
	nop
	nop
	nop
	nop
	BTG PORTD,2  ;toggle ~R
	incf COUNT4
	MOVLW 0X02
	CPFSEQ COUNT4
LPP1:
	goto LPLAST
LPP2:
	incf COUNT4
	GOTO LP3
LP3:
	BTG PORTD,1 	;toggle Y
	nop 		;5micros delay
	nop
	nop
	nop
	nop
	BTG PORTD,4 	;toggle ~Y
	movlw 0x03
	cpfseq COUNT4
LP4:
	bra LPLAST
LP5:
	btg PORTD,3 	;TOGGLE B
	nop 		;5micros delay
	nop
	nop
	nop
	nop
	btg PORTD,0 	;TOGGLE ~B
	decf COUNT4
	decf COUNT4
LP6:
	movlw 0xd0
  	movwf TMR3H
  	clrf TMR3L
LPLAST:
	retfie
;initialisation of portd
INIT
	clrf PORTD
	clrf LATD
	clrf TRISD
	movlw red
	movwf LATD
return
END
