hittinswitches98
Ok so basically the problem I have is I need to go from 3.3v dc to 12v dc. Here's whats going on. I have a Technologic Systems TS-7300 board that I am programming to. What I want to do is use outputs from the board to control 12v relays in a car which control valves for an air suspension. So basically in my program, when a user hits button 1 on the keypad, a pin on the board goes from active low (0v) to active high (3.3v). I want to be able to step the voltage up from the 3.3v signal to 12v so I can activate my relay which will then control the valve.
The relays are just 12v SPDT and are configured as follow:
pin 30 is +12v from the car
pin 86 is ground
pin 87 is my output which will go to the valve (12v)
pin 85 is my input from my board.
So basically I need to step up the voltage from 3.3v to 12v and I'm really not sure how to go about this. Can anyone help or give me some suggestions. The only thing keeping this from working is really that I don't know how to step up the voltage. The programming is all done and I've verified that the pins go from 0 to 3.3v then back to 0 upon a keypress, so that part is all done.
I have a ULN2003A that someone recommended to me, but I can't seem to get that to work. Not sure what I'm missing, but I appreciate any help anyone can give and if anything more needs to be explained, please let me know.
-Scott
pin 86 is ground
-Scott
