How to do a serial port streaming in PIC xc8 compiler
magvitron
Active Member
Hi I came accorss this on the arduino play ground. How can this be implemented on xc8 compiler of PIC?
Iam reading this stream via PIC
HTML:
44 05 00 95 00 44 05 00 95 00 44 05 00 95 00 44        D..•.D..•.D..•.D
05 00 95 00 44 05 00 95 00 44 05 00 95 00 44 05        ..•.D..•.D..•.D.
00 95 00 44 05 00 95 00 44 05 00 95 00 44 05 00        .•.D..•.D..•.D..
95 00 44 05 00 95 00 44 05 00 95 00 44 05 00 95        •.D..•.D..•.D..•
00 44 05 00 95 00 44 05 00 95 00 44 05 00 95 00        .D..•.D..•.D..•.
@baud rate of 203400bps
my code is:
unsigned int rem,temp_num,i;
static char retnum[21];
Initialize the serial port
@ 160000 and 230400bps
Requires :none
Returns : none
void uart_init()
{//Enables Serial port
/*RCSTA RECIEVER CONTROL REGISTER*/
RCSTA1bits.SPEN = 1;
RCSTA1bits.RX9=0;//8 bit reception
RCSTA1bits.CREN = 1; //enable the reciever
  TRISCbits.TRISC7=0;
  TRISCbits.TRISC6=0;
/*TXSTAx: TRANSMIT STATUS AND CONTROL REGISTER */
TXSTA1bits.BRGH=1;//baud rate high bits
TXSTA1bits.SYNC=0;//assynchronous mode
TXSTA1bits.TX9=0; //8 bit reception
TXSTA1bits.TRMT=1;//reset the buffer
TXSTA1bits.CSRC=0;// Master mode  (clock generated internally from BRG)
/*BAUDCONx: BAUD RATE CONTROL REGISTER*/
BAUDCON1bits.BRG16=1;//16 bit Baud rate is enabled
SPBRGH1 = 0;
SPBRG1 = 16;//2;
//(((_XTAL_FREQ/baud)/4)-1);
//FCY/64)/BAUD) - 1;
// set baud to 9600  FCY=20000000
//Turn On the Tx and Rx
//interrptbased reception
INTCONbits.GIE=1;
INTCONbits.PEIE=1;
  PIE1bits.RC1IE=1;
TXSTA1bits.TXEN=1;
RCSTA1bits.CREN=1;
//Function for sending char
//Requires  : <Xc.h>,Uartinit
//Returns  : None
//Parameters: None
void uart_char(char data)
TXREG1= data;
  while(!TXSTA1bits.TRMT);
//Function for read to a buffer
//Returns  : None
//Parameters: None
void uart_read2buff()
int count;
char ch;
count = 0;
ch = uart_read();
while ((ch > 0) && (count<64))
  g_rxr[count] = ch; // write to buffer
  count=count+1; // increment count
  //uart_numb(count); // echo
  ch = uart_read(); // read next char
g_rxr[count]='\0';
//uart_string("out of here");
//Function for reciveing from serial
//Returns  : None
//Parameters: None
char uart_read()
while(!RC1IF);
RC1IF=0;
return RCREG1;
//Function for sending number
//Returns  : None
//Parameters: None
void uart_numb(int num)
temp_num=num;
if(num==0)
    uart_char(48);
else
while(temp_num!=0)
  temp_num=temp_num/10;
  rem=rem++;
  sprintf( retnum, "%ul", num );
  for(i=0;i<=(rem-1);i++)
  uart_char(retnum[i]);
  rem=0;
//Function for new line,uart char
//Returns  : None
//Parameters: None
void uart_newline()
  uart_char(0x0A);
  uart_char(0x0D);
//Function for sending string
//Returns  : None
//Parameters: None
void uart_string(char *str)
//take address vaue of the string in pointer *str
    int i=0;
    while(str[i]!='\0')
    // loop will go on till the NULL charaters is soon in string
        uart_char(str[i]);
        // sending data on CD byte by byte
        i++;
    return;
//Function for dumping string
//until 0xff is recieved
//Returns  : None
//Parameters: None
void uart_dump(char *str)
//take address vaue of the string in pionter *str
    for(static int i=0;i<=UART_ARRAY;i++)
        uart_newline();
        uart_numb(i);
        uart_char(':');
        uart_numb(str[i]);
    return;
//Returns  : None
//Parameters: None
void uart_stringln(char *str)
    uart_newline();
//    int i=0;
    while(str[i]!='\0')
    // loop will go on till the NULL charaters is seen in string
        uart_char(str[i]);
        i++;
main:
#include<xc.h>
#include<string.h>
#include<stdlib.h>
#include "UART.h"
#include "MICRO.h"
#include "global.h"
#include "delays.h"
#define _XTAL_FREQ 16000000
#pragma config XINST  = OFF
#pragma config WDTEN  = OFF
#pragma config FOSC  = HS2
#pragma config CANMX  = PORTB
#pragma config PLLCFG = OFF
void cli();
void sei();
void main()
    char read1tag[3]={0x44,0x05,0x01};
    char read2tag[3]={0x44,0x05,0x02};
    char read3tag[3]={0x44,0x05,0x03};
    char read4tag[3]={0x44,0x05,0x04};
    char read5tag[3]={0x44,0x05,0x05};
    char errorcode[]="error code";
    uart_init();
    //uart_string("Done!");
    micro91_check_hardware();
    delay(100);
      micro91_check_firmware();
      uart_newline();
    uart_stringln(errorcode);
    uart_numb(error_code);
    delay(1000);
    g_clear_rxbuff();
    cli();
    char a;
    while(1)
        micro91_start_scan();
        a=uart_read();
        if(a==0x44)
            uart_string("oh yeah");
        else
        {uart_string("oh NO");
        micro91_stop_scan();
        g_clear_rxbuff();
    //(strstr(g_rxr,read2tag)))
//    uart_dump(g_rxr);
while(1);
Set interrrupt
void sei()
INTCONbits.GIE=1;
INTCONbits.PEIE=1;
//PIE1bits.RC1IE=1;
Clear interrrupt
void cli()
INTCONbits.GIE=0;
INTCONbits.PEIE=0;
// PIE1bits.RC1IE=0;
fuction to read from UART interrupt
configured on asynchronous mode
configured in uart.c in the function
uart_init()
void interrupt eusart_read()
    if(g_count<=UART_ARRAY)
        if (PIR1bits.RC1IF==1)
              RC1IF=0;
            g_rxr[g_count] = RCREG1 ;
              g_count=g_count+1;
    else
    g_count=0;
i want to stream until the characters : 0x44, 0x16 is received.
do I need state machine or something?
