Hello
Im using PIC18F4220, 20MHz ceramic, C18 compiler.
I have a running project where im taking temperature readings after every 300ms intervals and display on 16x2 LCD.
Im using thermistor MCP9701A. I have 8bit ADC enabled on my PIC and im only reading the high byte ADRESH.
My V+ref == Vdd and V-ref == Vss.
All seems to work fine and im getting good temp read outs going up to room temperature. This i compared with a
precision digital thermometer. The only problem is when the temperature drops below zero, i get only two fixed
numbers showing on LCD.... -55C and -35C.
Please can anyone explain why im getting some crazing -ve reading where in fact my -ve temperature reading
should not be dropping more than -2C....and this should show up on LCD as " -02C ".
Below is my code...plz see it and kindly let me know where the mistake might be.
Haseeb
Haseeb
#include <p18f4220.h>
#include <delays.h>
#pragma config OSC = HS
#pragma config WDT = OFF
#pragma config LVP = OFF
void SendLCD(unsigned char Byte, unsigned char type); //LCD display function
#define LCD LATD //LCD Latch PORT
#define LCD_RS LATEbits.LATE0 //Register Select (0: Instruction/ 1: Data)
#define LCD_E LATEbits.LATE2 //Enable (Starts data read/write)
#define LED LATCbits.LATC3 //power up LED
unsigned char minus = 0, //-ve flag...for -ve sign activation
bin = 0, //temp buffer variable for ADC value for BCD conversion process
//BCD coversion variables
d0 = 0,
d1 = 0,
d2 = 0;
void main(void)
//Configure ADC
ADCON1 = 0b00001110 ; //VREF- = VSS,
//VREF+ = VDD,
//Enable AN0 only...rest all Digital
ADCON0 = 0b00000000; //Select channel 0 (AN0),
//ADC Idle,
//ADC Dissabled
ADCON2 = 0b00001100; //Left Justified for 8bit ADC scaling
//ADC Acquisition Time 2TAD,
//ADC Conversion Clock FOSC/4
PORTA = 0; //initiallize PORTA
TRISAbits.TRISA0 = 1; // Analog Channel 0 (AN0 input)
PORTB = 0; //intialize PORTB
TRISBbits.TRISB3 = 1; //swtich 1 input
TRISBbits.TRISB4 = 1; //switch 2 input
TRISBbits.TRISB5 = 1; //switch 3 input
PORTC = 0; //intialize PORTC
TRISCbits.TRISC3 = 0; //LED
PORTD = 0; //initiallize PORTD
TRISD = 0x00; //LCD output
PORTE = 0; //initiallize PORTE
TRISEbits.TRISE0 = 0; //LCD Register Select (to LCD Pin 4)
TRISEbits.TRISE2 = 0; //LCD Enable (to LCD Pin 6)
INTCON = 0; //dissable all interrupts
Delay10KTCYx(10); //20ms wait for LCD power up
//Initialize the LCD
LCD = 0x00; //clear LCD PORTD pins
Delay1KTCYx(25); //delay 5mS
SendLCD(0x03,0); //Initialization command
Delay100TCYx(8); //delay 160uS
SendLCD(0x3C,0); //Interface lenght is 8 bits long, 2-lines, 5x10 dots
SendLCD(0x10,0); //Turn off LCD
SendLCD(0x01,0); //Clear LCD
SendLCD(0x06,0); //Increment the cursor after each byte written
SendLCD(0x0C,0); //Turn on LCD, cursor off, cursor blinking off
//Power up flashing LED
LED = 1;
Delay10KTCYx(125); //250ms delay
LED = 0;
LED = 1;
LED = 0;
ADCON0bits.ADON = 1; //Enable ADC
while(1) //loop forever
ADCON0bits.GO_DONE = 1; //Start ADC Conversion
while (ADCON0bits.GO_DONE == 1); //Wait until Conversion finishes
bin = ADRESH; // reading ADC High byte only for 8bit ADC scale
if(bin < 20) //below 0 deg C ... (0 deg C @ 400mV)
minus = 1; //activate -ve sign
bin = bin - 20; //offset adjustment ... (0 deg C @ 400mV)
//convert ADC value to BCD
d1 = bin % 10;
d0 = (bin / 10) % 10;
//convert BCD digit numbers to ASCII text characters for LCD
d0 += '0';
d1 += '0';
SendLCD(0x80,0); //activate LCD line 1
//if temperature is in -ve ... then print -ve sign on LCD
if(minus == 1)
SendLCD('-',1);
minus = 0; //reset minus sign flag
else //temperature is in +ve so erase minus sign (blank space print)
SendLCD(' ',1);
//print the temperature on LCD
SendLCD(d0,1);
SendLCD(d1,1);
SendLCD('C',1);
Delay10KTCYx(150); //300ms delay
}// end of main while loop
} //end of main()
LCD_RS = type; //Set whether it is a Command (0) or Data/Char (1)
LCD = Byte; //assign the new data to the LCD PORTD
LCD_E = 1; //Set Enable High
LCD_E = 0; //Set Enable Low
