I need a 120 VAC primary winding and 48 VAC secondary winding with CT. The transformer needs to be 250 watts. I need 160 watts from each 24 VAC winding.
No transformers like this for sale on ebay. I have several old transformers I can rewind. I need to determine the power rating if a transformer by the core size?
So far I have not found any formulas in my book or online, how to calculate power by core size.
I have several used transformers I can rewind. Some are marked and some are not.
I have a 480/240 VAC 500 watt transformer step down to 120 VAC core area is 3.682 sq inches.
I have another 480/240 VAC 500 watt transformer step down to 120 VAC core area is 5.764 sq inches.
I have 7 microwave oven shunt type transformers 1000 watts, core area is 3.781 sq inches. It is impossible to over load a shunt transformer max amp load on the primary should be 8.33 amps.
