How to change a Single bit in MikroC
I don't use microC but in other Cs it's done in various ways.
PORTA.1=1;
PORTA|=2;
RA1=1;
PORTAbits.RA1=1;
Most of the compilers I've seen will turn any of the above into a single bsf instruction.
Edit, forgot I have the manual here. It's PORTA.F1=1;
Why F1 I have no idea.
Bit Addressing
Taken from the Mikroe documentation
sbit type
The mikroC PRO for PIC compiler has sbit data type which provides access to bit-addressable SFRs. You can access them in the following manner:
sbit LEDA at PORTA.B0;
sbit bit_name at sfr-name.B<bit-position>;
sbit LEDB at PORTB.F0;
sbit bit_name at sfr-name.F<bit-position>;
// If you are familiar with a particular MCU and its ports and direction registers (TRIS), you can access bits by their names:
sbit LEDC at RC0_bit;
sbit bit_name at R<port-letter><bit-position>_bit;
sbit TRISC0 at TRISC0_bit;
sbit bit_name at TRIS<port-letter><bit-position>_bit;
Also have a look at this thread - I know it's on MikroB but most of their compliers are the same.
Hope this helps:)
You use the PORTA.f0
It's kind of crazy They use the PORT.F1 the f matches the numbers on there
experimenter boards that way if you wanted to use pin f1 you use porta.f1.
I like using it for small chips
You can all so hit a bit like this
         PORTB |=  (1<<5);  // Sets bit five of portb
The good thing about this is it works in any C boostC HI-tech C18 microC you name it
PORTB |=  (1<<0);  // Sets bit O of portb
PORTB |=  (1<<1);  // Sets bit one of portb
PORTB |=  (1<<2);  // Sets bit two of portb
PORTB |=  (1<<3);  // Sets bit threeof portb
PORTB |=  (1<<4);  // Sets bit four of portb
