How spot random PIN diodes?
throbscottle
I've been sorting out my board pull smd diode collection (result of looking for a schottky for the ridiculously complicated drill controller). Many possible types for most of the case markings, and a lot have PIN diode listed as a possible type. (I don't know where they came from so that doesn't help). How can I tell if that is what they are?
It's much easier to tell if you order them from Digikey or other authorized distributor and simply read the package.
I completely agree, it's a waste of time pulling SMD's as many have no markings at all, and those that do often are impossible to identify what the code means.
You've both missed the point. I don't actually want to use a PIN diode for anything, it's not something I'm interested in using (well, until I am).
I have an effective system for retrieval (heat and scrape) sorting (mini magnetised triangle trays on a white piece of steel sheet and a small whiteboard marker) storage (labelled small centrifuge tubes grouped in labelled bags, all in lidded container) and identification (bootleg copy of the Turuta SMD codebook + BangGood Hiland component tester + homemade test jig) and retrieval (a spreadsheet which contains lines copied from the codebook of all the possible devices for any one top mark that I actually have). So if I want a particular type of component, I can look at my stock, retrieve R's and C's directly, semiconductors I can just look up the type of device I want in the spreadsheet and test the matching devices to make sure they are actually as expected. Around 95% of devices are identifiable with 95% accuracy.
But diodes are a bit harder because for any top mark there is a greater diversity of candidates for any device. I can still pin it down to one exact diode but it takes more work, and if my requirement is so specific it actually matters then I would just buy it anyway. But usually I want "any switching diode" or "any rectifier over x amps and y volts" or "any schottky diode" or "any zener of x volts", so it doesn't matter, any purchase would be cost based so why pay when my own time is free and I usually get what I want much quicker?
So going back to PIN diodes, the point is, I see a lot of candidates for any diode top mark which include varicap and PIN types. 99% of what I have is ordinary diodes, but supposing I do have an odd PIN diode in there? My curiosity is piqued, what traits do I look for?
We may have missed the point but your initial post did not motivate us to stop and aim accurately.
At less than MHz (10s of MHz) frequencies, a PIN Diode looks a lot like a rectifier diode. Do you have RF test equipment.
Thank you for that video Mickster.
That guy w2aew does some very good instructional videos, always well presented.
If I remember correctly, he is an applications engineer for Tektronix.
Ahh, apologies, I will try to motivate your aim in future ;) RF testing is possible for me but it's all very kludgy in the GSF (Garden Shed Facility)
Thanks Mickster for the excellent video. Now I'm a little more motivated to experiment in the world of RF. I guess at the DC level I could look out for that large forward capacitance.
Doh!
I thought in the video he said they have a lot of forward capacitance and tiny reverse capacitance. I'll have to watch it again.
