how i design am transmitter
Parth86
how can i design am transmitter
hi
i am basic confused
in books, i read bunch of theory in pieces but i don't know how they work together. i have no idea where i would apply. so i fell difficulty
________________________________________
i am trying to design am transmitter for short distance to learn basic calculations of transmitter
AM TRANSMITTER
modulations type am modulations
frequency range 1mhz
voltage supply 12v
transmitting distance 80m-100m
audio frequency 20hz-20khz
antenna
low level modulated with linear amplifier
i know i need following circuit to make transmitter
-audio amplifier circuit
-Oscillator circuit
-RF amplifier circuit
-microphone
i need circuit that amplify the signal of mics
i know to make amplifier circuit
transistor NPN, PNP transistor
mode ce, cb, ce
class A, B, C amplifier
for design audio amplifier we select following parameters
audio source -microphone
transistor npn transistor
mode common emitter
class class A power amplifier
transistor ratings
collector emitter voltage=30v
collector base voltage=60v
emitter base voltage=5v
collector current=800mA
power=500mW
my questions
1. specification of microphone
frequency response
impedance
2what is gain of audio amplifier
3.which stage is used for audio amplifier
single stage
two stage transistor
4.what is gain of rf amplifier
5.how we decide what gain is needed for signal
6.which oscillator is used and what is frequency
wien bridge
colpit
crystal
7.what is length of antenna
if possible please explain with mathematical calculations
i don't care bad quality of transmitter
i am basic confused
Don't you have a teacher and a text book like all other students have?
AM TRANSMITTER
voltage supply 12v
Don't you know that a 1MHz AM radio receives only about 50Hz to 3kHz? Why do you want 20kHz?
-Oscillator circuit
-microphone
Then show us the circuits you designed for the transmitter.
There are hundreds of mic preamp circuits shown in Google.
mode ce, cb, ce
Select the type of circuit then show it.
mode common emitter
Then show it.
transistor ratings
power=500mW
Almost ANY transistor can be an audio amplifier but yours does not have a part number.
Show us your circuit.
my questions
frequency response
impedance
Select which type of microphone:
Electret or Dynamic.
The gain required depends on the transmitter's modulator circuit.
3.which number of stages is used for audio amplifier
single stage
It depends on the amplifier circuit and the amount of gain needed.
It depends on how much output power you need (and the sensitivity of the AM radio) and the amount of output level from the oscillator.
Use common sense.
wien bridge
colpit
crystal
You listed the frequency above. Weren't you taught about AM transmitters and high frequency oscillators?
For your very short range the antenna can be very short or be a ferrite bar like used in AM radios.
Why didn't you learn them in school?
i have text books but in books lot of theory is given in pieces i feel difficulty how we apply for this circuit
first i build block diagram of transmitter
electret mic
please give hint for this terms
Why didn't you learn them in school?[/QUOTE]
in school they teach me theory and how make amplifier oscillator circuit but they don't teach real example how we make transmitter with amplifier,oscillator circuit
i can make amplifier ,oscillator circuit when i know the input and output for circuit
but here my transmitter circuit i have no idea how we decide gain for this circuit please give idea how we decide gain for every transmitter
First you must decide on the amount of output power the transmitter must give into a short antenna that does not match the very low frequency it operates at. You must know the sensitivity of the radio or measure it then calculate the output power needed for the range you want.
Then select an AM modulator which will have a certain input level required from the mic preamp. Then select an oscillator type.
I looked in Google for AM Radio Transmitter Circuit and there are many schematics.
The 3rd link has a fairly simple circuit.
The 4th link has Wikipedia showing how to design an AM Radio Transmitter.
There are hundreds of more good links about it.
