doitmyselfer0523
Sorry to post such a stupid question, but I was hoping the gurus out there could shed some light on this subject for me.
I have a Garmin navigation system for my car. In the cold weather it fell off of the windshield and landed directly on the power connector. The force of the fall on the power connector broke the power connector on the circuit board. I took it all apart and soldered it back together, but the connection is askew and it doesn’t work unless I physically hold the connector with my hands….
This Garmin device has a battery input in which two AA batteries can power the unit, and this works fine, but I don’t want to keep putting batteries into the unit, I want to use the car-power plug.
So, I soldered the car adapter directly wire directly to the battery input leads. The only problem is that where the batteries provided (2 X 1.5 volts) 3 volts, the car adapter is providing between 5 and 7 volts. The Garmin is not at all happy with the extra voltage at the battery input and doesn’t work.
Yes, I tested the unit back with just batteries to verify that I had not blown up the unit; it still works fine with batteries.
So, I ask a friend of mine how to build something to cut the voltage down to 3 volts. He tells me to use a couple of rechargeable batteries in-line and they would regulate the voltage down. Sounded good to me, so I built the circuit… The positive output of the car charger to the negative battery lead, inline with the second battery, and behold… the voltage was summed, not regulated down. I ended up with 5v + 3V = 8V.
Yes, I am too cheap to purchase another Garmin; the one I have works fine, if I can just feed it the 3 volts it wants. And yes, I am too cheap to go to the auto parts store and purchase one of those multi-voltage output devices. I want to fix this thing and hopefully, you-all are going to help me.
So, my technical cyber friends, what do I have to do to cut the voltage down from 5V (or 7V, I can’t remember) down to 3VDC? Resisters? The worst part is I was an electronics technician in a prior life, but hell if I can remember any of it. I never got to much into power supplies, and if I did I swapped out the whole thing and let someone else back at the depot fix it.
Thanks for your time; please be kind in your replies.
