i am doing a project with PIC16f877a via i2c to control the si570
the pic is put on the matrix multimedia version 3 development board.
now i want to change the frequency by press the button on the board.
for example: when i press button SA0, the frequency should change
but i dont know how to write the code. the button SA0 is connected to the RA0 of the PIC.
any one can help me?
here is my code
here is my code
#include <math.h>
#include <16f877afloat.h>
#include <pic16f877a.h>
//#include <pic.h>
#include "i2c.h"
#define fout_start_up 56.5 // in MHz
#define frequency_list_length 20
#define POW_2_16 65536.0 //these must be floating point number
#define POW_2_24 16777216.0 //especially 2^28 so that there is enough
#define POW_2_28 268435456.0 //memory to use them in thecalculation
#define fxtal 114.285 ; // in MHz
static bank2 float FXTAL;
static bank2 unsigned char j;
static bank2 unsigned char INITIAL_N1;
static bank2 unsigned char INITIAL_HSDIV;
static bank2 signed long INITIAL_RFREQ_LONG;
static bank2 unsigned long FRAC_BITS; // Double Floating Point Precision Method
static bank2 unsigned int CURR_FREQ; // Holds the index of the current frequency
// being output
static bank2 unsigned char reg[6];
static bank2 unsigned char R137;
static bank2 const float fdco_max = 5670; // in MHz
static bank2 const float fdco_min = 4850; // in MHz
static bank2 const unsigned char bank2 HS_DIV[6] = {11, 9, 7, 6, 5, 4};
static bank2 float rfreq;
static bank2 const float fout0 = fout_start_up;
static bank1 float fout1 [frequency_list_length] =
{27.000000 ,
74.175824 ,
100.000000 ,
125.000000 ,
161.132813 ,
172.642300 ,
200.000000 ,
212.500000 ,
368.640000 ,
491.520000 ,
622.080000 ,
644.531250 ,
666.514286 ,
690.569196 ,
704.380580 ,
800.000000 ,
933.120000 ,
1000.000000 ,
1400.000000 ,
fout_start_up };
// SetBits
// Return Value : unsigned char
// Parameters :
// 1) unsigned char original - original state of variable to be changed
// 2) unsigned char reset_mask - contains mask of bits that will reset the
// the original char variable.
// 3) unsigned char new_val - contains a mask of bits that need to be set in
// the original variable.
// This function sets appropriate bits in an unsigned char variable
unsigned char SetBits(unsigned char original, unsigned char reset_mask, unsigned char new_val)
return (( original & reset_mask ) | new_val );
void FreProg (void)
static bank2 int i; // temporary variable used in for loops
static bank2 unsigned char n1; // Output divider that is modified and used in
// calculating the new RFREQ
static bank2 unsigned char hsdiv; // Output divider that is modified and used in
static bank2 unsigned char reg137; // Stores the contents of Register 137
// on Si57x
static bank2 unsigned char validCombo; // Flag that is set to 1 if a valid combination
// of N1 and HS_DIV is found
static bank2 unsigned int divider_max; // Maximum divider for HS_DIV and N1 combination
static bank2 unsigned int curr_div; // Minimum divider for HS_DIV and N1 combination
static bank2 unsigned int whole; // Used in Double Floating Point Precision Method
static bank2 unsigned long final_rfreq_long; // Final REFREQ that is sent to the Si57x
static bank2 float curr_n1; // Used to calculate the final N1 to send to the
static bank2 float n1_tmp; // Si570
static bank2 float ratio = 0; // Will hold the final ratio to multiply the initial
// REFREQ by to acheive the final RFREQ
// find dividers (get the max and min divider range for the HS_DIV and N1 combo)
divider_max = floor(fdco_max / fout1[CURR_FREQ]); //floorf for SDCC
curr_div = ceil(fdco_min / fout1[CURR_FREQ]); //ceilf for SDCC
validCombo = 0;
while (curr_div <= divider_max)
//check all the HS_DIV values with the next curr_div
for(i=0; i<6; i++)
// get the next possible n1 value
hsdiv = HS_DIV[i];
curr_n1 = (curr_div * 1.0) / (hsdiv * 1.0);
// Determine if curr_n1 is an integer and an even number or one
// then it will be a valid divider option for the new frequency
n1_tmp = floor(curr_n1);
n1_tmp = curr_n1 - n1_tmp;
if(n1_tmp == 0.0) // Then curr_n1 is an integer
n1 = (unsigned char) curr_n1;
if( (n1 == 1) || ((n1 & 1) == 0) ) // Then the calculated N1 is
{ // either 1 or an even number
validCombo = 1;
if(validCombo == 1) break; // Divider was found, exit loop
curr_div = curr_div + 1; // If a valid divider is not found,
// increment curr_div and loop
// If validCombo == 0 at this point, then there is an error
// in the calculation. Check if the provided FOUT0 and FOUT1
// are valid frequencies
// old method for New RFREQ calculation
rfreq = (fout1[CURR_FREQ] * n1 * hsdiv) / fxtal;
// Calculate RFREQ organizing the float variables to save precision;
// RFREQ is kept as an unsigned long
// only 32 bits are available in the long format
// RFREQ in the device has 34 bits of precision
// only 34 of the 38 bits are needed since RFREQ is between 42.0 and
// 50.0 for fxtal of 114.285MHz (nominal)
ratio = fout1[CURR_FREQ] / fout0; // Try to keep ration near 1
// to maintain precision
ratio = ratio * (((float)n1)/((float)INITIAL_N1));
ratio = ratio * (((float)hsdiv)/((float)INITIAL_HSDIV));
final_rfreq_long = ratio * INITIAL_RFREQ_LONG; // Calculate final RFREQ value
// using ratio computed above
for(i = 0; i < 6; i++)
reg[i] = 0; //clear registers
hsdiv = hsdiv - 4; // Subtract 4 because of the offset of HS_DIV.
// Ex: "000" maps to 4, "001" maps to 5
//reset this memory
//reg[0] = 0;
//set the top 3 bits of reg[0] which will correspond to Register 7 on Si570
reg[0] = (hsdiv << 5);
// convert new N1 to the binary representation
if(n1 == 1)
n1 = 0; //Corner case for N1. If N1=1, it is represented as "00000000"
else if((n1 & 1) == 0)
n1 = n1 - 1; // If n1 is even, round down to closest odd number.
// Write correct new values to reg[0] through reg[6]
// These will be sent to the Si570 and will update the output frequency
reg[0] = SetBits(reg[0], 0xE0, (n1 >> 2)); // Set N1 part of reg[0]
reg[1] = (n1 & 3) << 6; // Set N1 part of reg[1]
//Write new version of RFREQ to corresponding registers
reg[1] = reg[1] | (final_rfreq_long >> 30);
reg[2] = final_rfreq_long >> 22;
reg[3] = final_rfreq_long >> 14;
reg[4] = final_rfreq_long >> 6;
reg[5] = final_rfreq_long << 2;
// convert new RFREQ to the binary representation
// separate the integer part
whole = floor(rfreq);
// get the binary representation of the fractional part
FRAC_BITS = floor((rfreq - whole) * POW_2_28);
// set reg 12 to 10 making frac_bits smaller by
// shifting off the last 8 bits everytime
for(i=5; i >=3; i--)
reg[i] = FRAC_BITS & 0xFF;
FRAC_BITS = FRAC_BITS >> 8;
// set the last 4 bits of the fractional portion in reg 9
reg[2] = SetBits(reg[2], 0xF0, (FRAC_BITS & 0xF));
// set the integer portion of RFREQ across reg 8 and 9
reg[2] = SetBits(reg[2], 0x0F, (whole & 0xF) << 4);
reg[1] = SetBits(reg[1], 0xC0, (whole >> 4) & 0x3F);
Freeze();
Read_Si570();
Unfreeze();
NewF();
void ReadStartUpConfiguration (void)
int i;
recall();
Read_Si570();
INITIAL_HSDIV = ((reg[0] & 0xE0) >> 5) + 4; // Get value fo INITIAL_HSDIV from REG[0]
// 4 is added to this because the bits "000" correspond to an HSDIV of 4, so there is
// an offset of 4. See the register 7 of Si570 datasheet for more information.
INITIAL_N1 = (( reg[0] & 0x1F ) << 2 ) + (( reg[1] & 0xC0 ) >> 6 );
// Get correct value of INITIAL_N1 by adding parts of REG[0] and REG[1]
if(INITIAL_N1 == 0)
INITIAL_N1 = 1; // This is a corner case of N1
else if(INITIAL_N1 & 1 != 0)
INITIAL_N1 = INITIAL_N1 + 1; // As per datasheet, illegal odd divider values should
// be rounded up to the nearest even value.
// RFREQ conversion (reconstruct the fractional portion (bits 0 to 28) from the registers)
// (this method requires double precision floating point data type to be accurate)
FRAC_BITS = (( reg[2] & 0xF ) * POW_2_24 );
FRAC_BITS = FRAC_BITS + (reg[3] * POW_2_16);
FRAC_BITS = FRAC_BITS + (reg[4] * 256);
FRAC_BITS = FRAC_BITS + reg[5];
rfreq = FRAC_BITS;
rfreq = rfreq / POW_2_28;
// Read initial value for RFREQ. A 34-bit number is fit into a 32-bit space
// by ignoring lower 2 bits.
INITIAL_RFREQ_LONG = ( reg[1] & 0x3F );
INITIAL_RFREQ_LONG = (INITIAL_RFREQ_LONG << 8) + ( reg[2] );
INITIAL_RFREQ_LONG = (INITIAL_RFREQ_LONG << 8) + ( reg[3] );
INITIAL_RFREQ_LONG = (INITIAL_RFREQ_LONG << 8) + ( reg[4] );
INITIAL_RFREQ_LONG = (INITIAL_RFREQ_LONG << 6) + ( reg[5] >> 2 );
// RFREQ conversion (reconstruct the integer portion from the registers)
rfreq = rfreq + ( (( reg[1] & 0x3F ) << 4 ) + (( reg[2] & 0xF0 ) >> 4 ) );
// Crystal Frequency (FXTAL) calculation
FXTAL = (fout0 * INITIAL_N1 * INITIAL_HSDIV) / rfreq;
// Port_Init
// Return Value : None
// Parameters : None
// Configure the Crossbar and GPIO ports.
// RC4 SDA
// RC3 SCL
// RA1 Used as input switch 'next' on board
void port_init()
TRISA=0X00; //set A as input
TRISC=0X00;
PORTA=0XFF;
PORTC=0XE7;
void main()
int i;
port_init();
CURR_FREQ = frequency_list_length - 1; // Start up frequency is the last element in the array.
// Set CURR_FREQ index to point to last element
ReadStartUpConfiguration();
CURR_FREQ = 0; // After 'next' is pressed, first frequency element in FOUT1
// will be output
while(1) // Loop forever
while(!RA4)
//delay(300ms);
FreProg();
CURR_FREQ = CURR_FREQ + 1; // Update index for next frequency
if (CURR_FREQ > (frequency_list_length - 1))
CURR_FREQ = 0; // Wrap around index after overflow
