Hey all again,
Just wanna run something past all of you wise folks..
As some of you know, i am doing CURRENT SENSING usin ga CURRENT TRANSFORMER, and it works a treat, by passing the wire i want to measure thru the core, and passing the output thru a bridge + some C's and R's i get a voltage PROPORTIONAL to the line current and my ADC converts it fine.
Now i have 4 WIRES to be measured, and instead of having 4 CURRENT TRANSFORMERS connected to 4 AtoDs , i want to pass ALL 4 WIRES thru ONE transformer, and i have tried this and it works,
When i want to acquire channel1, i turn on ch1 and turn 2/3/4 off, i then take the ADC measurement and this all works fine, BUT under normal running conditions, i.e. when im not taking a sample, i MAY have all 4 ON... and obviosuly this will produce 4 x the voltage i would expect, I am worried about this voltage, obv it will damage the input pin? what shall i do?
Use a relay to disconnect the wires going to the input pin?
Any other ideas????
Spec:
4 wires... all can be controlled to be on/off/dim-able
1 current transformer
i have enough ADC ports and DIGI out pprts (for relay) to do the job
HELPPPPP
Any other ideas????
Spec:
HELPPPPP
