jackmorrison
I've gone a little outside my area of expertise in a section of a circuit I'm working on, and I'd be grateful for some advice. I need to boost the current drive of a voltage source to power an array of LEDs. Requirements for the circuit are:
Input: range as needed, nominally 1V to 3V, frequency DC to 5MHz; high impedance (direct from DAC or waveform generator)
Power: single-ended supply, prefer 6.5 to 12V
Output: about same voltage range as input (so gain of 0.5 to 1),
at least 500mA, prefer 1A (continuous). Load is 0-64 high-brightness LEDs via analog switches with switch capacitance up to 130pF each, LED capacitance unknown but maybe guess 10pF, so 10nF total
Size: ideally no more than 10x10mm for two channels
My initial design uses OPA2673 in voltage follower configuration: input to +IN, -IN tied to OUT; single-supply (-VS=ground, +VS=10V). This works for a little while, then the ($4) IC heats up and dies - even with no LED load connected. Initially I had the "GND" pin on the IC tied to ground, but now I think that's wrong. Also I notice the datasheet recommends 511ohm feedback resistor even in a voltage follower configuration. This part is only available in a QFN package which is a little tough to experiment with (although there are lower-power relatives available in SOIC).
Now I'm wondering if a simple NPN transistor circuit would be better. I threw together a test with a 2N2222 I had laying around, and it seems to work but a little slow.
So my questions are:
- what's the disadvantage of a single BJT voltage follower compared to an op-amp?
- any idea why the OPA2673 is not happy in this role?
- what's the right way to meet the above requirements?
Thanks for any help.
