HI TECH C config question
ghostman11
i would like to use hi tech c but i cant work out how to set the fuses, i found out you use a _config statement and ive looked in the manual but it dosnt make much sense, so can i use the #pragma config fuse statement like you do in C18?
Hi Ghostman.....In the header file, there are all the definitions...However if you use the config manager in MPLAB you can just insert the hex number
On the menu Configue/ confiutation bits... select the fuses then read the hex value....
