Hexadecimal subtraction : using absolute value
Steve311
Hi All,
What is the best way to represent a absolute value of a number in assembly?
Suppose I want to represent the following in decimal: ABS[-20 - (65)]???
OR Hex equivalevt with sign bit: ABS [0x94 - (0x41)]??
Thanks!
Just do a conditional test first to see which number is the greater, then subtract the lesser from the greater.
If is A > B, x = A - B
else x = B - A
Does that give you what you want?
Hi chris, yes and no actually. i assume that is in c, i am actually using assembly with an enhanced mid range pic. how is that converted into assembly?
To get the ABS value of Var do,
		movfw	Var		;move into W
		btfss	Var,7		;test if negative
		goto	notNegative	;no, so all done
		comf	Var,w		;complement and move to W
		addlw	1		;add 1 to complete negation
notNegative
The above loads W with the ABS value and leaves Var unchanged.
Edit, If you want the variable to be negated as well then do,
		comf	Var,f		;complement and keep in file
		incf	Var,f		;add 1 to get complete negation
notNegative	movfw	Var		;mov into W
