HELP WITH the CIRCUIT !!!
Lamax
I have this Battery charger with automatic disconnection. and i need to make the PCB but i tried with PCB Wizard but i want ! i need help ! please if someone can make it for me, with the parts **broken link removed**
PLEASE PLEASE HELP ME !
Can someone please help me, i need to get that circuit, to a printer circuit lines so i can make it !... please ! its urgent
If you're stuck with a program, why not just draw it manually?
It's a easy circuit, so if you already have the components then you know the dimension of them.
You could use Inkscape for manual drawing.
that help's me =D thank you, Ii'll check Inkscape, i'll let you know if something happend
I cant draw it ! im dum =D , well not dum i'm just starting to learn circuits, but i cant draw this circuit! can someone draw it for me please ! i've been trying of day and i cant
It will be hard for someone to draw the board without knowing the components. Do you have the components?
Yes i have them
This are the components
- Thyristors: 1 (SCR1) common-1 amp, 1 (SCR2) common 5 amps or more
- Resistors: 3 47Ω (ohms), 2 watts. (Watts), 1 pot of 750 Ω (ohms), 2 watts (W), 1 of 1 kW (kilo-ohms), (1000Ω = 1 kohm)
- Capacitors: 1 50 uF electrolytic capacitor, 12 volts or more, (uF = microfarads)
- Diodes: 3 of 3 amps rectifier diodes, zener diode 1 of 11 Volt, 1 W (watt)
- Transformer: 1 transformer secondary 12 Volt AC, 4 amps
thank you if u can draw the circuit ! =D
That's not enough. Need to know the distance between pin for each component AND the size of pins.
Hint: it's often standard dimensions, but espechially resistors may be different in your project compared to what a drawing will assume.
Also there ara many different pot's. Cant do a drawing without having all measurments of it.
Here's an indentical circuit that is much simpler. The circuit above has so many mistakes.
The full explanation of the circuit below is on Talking Electronics website under 200 Transistor circuits eBook.
As a starter in making a PCB, I recommend you to use express PCB. you can download it through internet for free.
