Help with PIC18F2455, Comparator interrupt
tzh0013
I'm using a PIC18F2455 microcontroller, I want the MCU detect a square wave and begins to send a signal for 0.5 seconds, and when the square wave stops, it can send another signal from another port for 0.5 seconds, The code complies but just doesn't function properly. (Works sometimes but fail in others )
could somebody help me with this , thanks
#include <stdio.h>
#include <stdlib.h>
#include <delays.h>
#include <p18f2455.h>
#pragma config FOSC = HS // Oscillator Selection:External oscillator
#pragma config WDT = OFF	// Watchdog Timer
#pragma config LVP = OFF	// Low Voltage ICSP(PIN 6):Disabled
unsigned int intr;
unsigned int state;
void InterruptHandlerHigh (void);
void main(void)
        state = 0;
        intr = 0;
        TRISC = 0;
        PIE2bits.CMIE = 1;
        TRISAbits.TRISA0 = 1;
        TRISAbits.TRISA1 = 0;
        TRISAbits.TRISA2 = 0;
        TRISAbits.TRISA3 = 1;
        TRISAbits.TRISA4 = 0;
        TRISAbits.TRISA5 = 0;
        TRISC = 0;
    	INTCONbits.PEIE = 1 ;
        INTCONbits.GIE = 1;
        CMCON = 0b00000001;
        while (1)
            switch (state)
            { case (0):
                    PORTAbits.RA5 = 0;
                    PORTCbits.RC0 = 0;
                    Delay10KTCYx(20);
                if ( intr)
                { state = 1;
                  intr = 0;
                else {state = 0;}
                break;
                case (1):
                   PORTAbits.RA5 = 0;
                    PORTCbits.RC0 =1;
                    Delay10KTCYx(100);
                    state = 2;
                    intr = 0;
                    break;
                case (2):
                    PORTAbits.RA5 = 0;
                PORTCbits.RC0 =0;
                Delay10KTCYx(20);
                if (intr)
                intr = 0;
                state = 2 ;}
                    else {
                    intr=0;
                    state = 3;
                      break;
                case (3):
                      PORTAbits.RA5 = 0;
                      PORTCbits.RC0 =0;
                     Delay10KTCYx(20);
                     if (intr)
                     intr = 0;
                     state = 2;}
                     else {state = 4;
                     intr = 0;
                     break;
                  case (4):
                      PORTAbits.RA5 = 1;
                PORTCbits.RC0 =0;
                    Delay10KTCYx(100);
                    state = 0;
                    intr = 0;
                    break;
                    default:
                    PORTAbits.RA5 = 0;
                    PORTCbits.RC0 = 0;
                        state = 0;
                       break;}
//**BEGIN INTERRUPT CONTROL**
#pragma code InterruptVectorHigh = 0x08		//interrupt pointer address (0x08 high priority)
void InterruptVectorHigh (void)
        _asm						//assembly code starts
        goto InterruptHandlerHigh	//interrupt control
        _endasm						//assembly code ends
#pragma code
#pragma interrupt InterruptHandlerHigh		//end interrupt control
void InterruptHandlerHigh()		// Declaration of InterruptHandler
        if(PIR2bits.CMIF){
                        intr = 1;
			PIR2bits.CMIF = 0;	//Clear Flag
    INTCONbits.GIE = 1;
    PIE2bits.CMIE = 1;  //Re-enable all interrupts
return;
[MODNOTE]Please use Code Tags The "#" symbol[/MODNOTE]
You need to share your variable "intr" between main and your ISR.... You can make it volatile so they can both access it...
There is a mechanism in place to do this correctly..
Sharing Temporary Data Sections Between ISR Functions And Non-ISR Functions
The tmpdata pragma may be used to share temporary data between interrupt service routines and non-interrupt functions. In the following example, the compiler temporary variables for the interrupt service routine isr and the non-interrupt function increment are both placed in the udata section isr_tmp.
void increment (int counter);
void isr (void);
#pragma interrupt isr nosave=section(".tmpdata")
void isr (void)
static int foo = 0;
increment (foo);
#pragma tmpdata isr_tmp
#pragma tmpdata
Note: When the compiler preserves context for an ISR, the compiler will automatically save the default temporary data section, .tmpdata, even if the tmpdata pragma specifies a different temporary data section for the ISR-called functions. In order to tell the compiler not to add the context saving overhead for the .tmpdata section, the nosave= clause of the interrupt pragma is used
This is from the C18 documentation..
I did, but it doesn't changes anything. The circuit is acting wired, it works fine in the room but acting redicules outside of the room.
I'm checking the other parts of the circuit and see if there's problem eslewhere, still thank you for your information .I'll let you know what's wrong after I find out.
