joeh100
I need some advice on tools used for the toner transfer method?
What laminater do you recommend? This "applicator" is recommended by pcbfx but is only good for .032" boards. The standard .064" boards are more common and cheaper, and I happen to already have a supply of them. Is anyone already successfully using a laminater with the thicker .064" boards?
What do you guys think about the **broken link removed** drill? I see that micromark has a similar drill for quite a bit less, listed as the microlux drill, although it has a lower rpm. Are any of you guys using these? Any other recommendations are welcome.
Finally what are you using to cut your boards. I've been thinking of getting a cheap scroll saw or table top band saw just for this, as opposed to my previous method of clamping a jigsaw upside down.
