Hi guys,
Newbie's first post so I need you to keep this dead simple for me!
I've done some research into hot wire cutters but I'm a bit vacant with electronics.
I've bought this power supply unit 3V-15V Adjustable 25/30A Max Power Supply : CB Radio Accessories : Maplin
Now for my question. My cutting bow is 2ft long. If I place a thicker nichrome wire than I get sufficient current draw and the wire heats up and cuts foam.
However, when I put in a thinner wire, It heats up but not enough to cut well.
Now my power unit only has variable volts. What would I need to do to get the thinner wire hotter (assuming changing the length of wire isn't a viable solution).
Can you give me any simple formulea I can use so I know what I'm doing in future regarding lenghts of wires, diameters, volts, ohms, amps etc?
I'll be honest and say I thought the thinner wire would get hotter than the thicker one so I'm just left confused!
Signed a girl playing with boys things
