Help with electronics, Op-amps and so on.
sarah90
(b) For the active filter circuit in (a) sketch the circuit. Then given that Ri = 10 kΩ, Ci = 10 nF, the feedback resistor Rf = 500 kΩ and the op-amp is a 741, determine the values of;
(i) The -3-dB frequency.
(ii) The time constant τ (in milliseconds)
(iii) The maximum voltage gain of this circuit in dB.
(iv) The voltage gain in dB at a frequency of f = 1 kHz.
crutschow
Most Helpful Member
So is there anything you understand about the questions?
We need a post of the circuit sketch.
sarah90
Op-amps second part
I need help as I find it too difficult to do.
crutschow
Most Helpful Member
Where is C1 connected on your schematic?
So you have no understanding of a simple RC filter or how an op amp works?
crutschow
Most Helpful Member
You didn't answer my first question about C1.
crutschow
Most Helpful Member
Please don't double post.
SneaKSz
H(z)= -Z2/Z1 ,
Z2=Rf
Z1=R1+1/jwC1 = (1+jwR1C1)/(jwC1)
H(z)= -Z2/Z1 =- s*Rf*C1/(1+sR1C1)
t=R1C1
-3dB = w=1/t => f= 1/(2*pi*t) = 1591.55 Hz
max voltage gain is when XC1 ~ 0 ohm => Gain = 20log*(rf/ri)=33.97dB
at last voltage gain at 1kHz =
Zi = R1+1/jwC1 = R1-j/wC1 = 10K-j15915.5 = 18822,9<-9,04
H(Z)=Zf/Zi = 500k<0 / 18822,9<-9,04 = 26.56 => dB = 20log(26.56 ) = 28.48 dB
Simulated and the values are correct :)
EE World Online Articles
Loading
