I need to build a simple circuit to detect dental caries. The employed technique is through measurement of electrical resistance of the tooth, which is approximately somewhere in the range of 0-4.4 M ohm for a caried tooth, and higher than 4.4 M ohm for normal teeth. An AC ohmeter circuit needs to be built to measure the resistance of tooth and this has to be interfaced with 3 LEDs to indicate the extent of cavities based on electrical resistance values. How do I build the circuit? How do I connect the LEDs with the AC ohmmeter? should I programme a micrcoontroller? How can I do it?
Please help
