simonedwards
I have a problem with a set of mains Horse Clippers which I hope someone can help me with.
The problem is that, intermittently, when I switch the clippers on, or switch them off it blows the fuse.
So, I've taken the beast to bits and I have found it is an AC series motor but it has a "condenser" which I suspect has gone faulty. So I called the service centre and they quote me £23 to replce the condenser !!!!
No way am I paying that much so I thought I'd fix it myself. The only problem is the "condenser" actually comprises 3 capacitors and I dont know how they are connected withing the condenser unit.
The condenser unit has 2 wires going in (the mains supply is connected to these) and 3 wires coming out. Two of these wires go to the Stator windings and then to the brushes, and the one remaining wire is soldered to laminated stator itself (kind of like and earth wire?). One of the mains input wires (the neutral) is common to one of the output wires which is connected to one of the stator windings / brushes.
The condenser has printed on it 0.1uf and 2x2500pf 250v. I therefore assume there are 3 caps in the condensor unit but I have no idea how they are connected up.
Does anyone have any idea? The caps themselves will cost a fraction of the unit so I'm hoping to fix this myself. Any help would be greatly appreciated.
Cheers
Simon
Cheers
Simon
