help verify parts will work for me
lokeycmos
im getting ready to order mmc caps and parts for terry filter. i would like someone more experienced to verify i have picked out the right parts/values/voltage ratings. terry filter schematic is here: **broken link removed**
for terry filter im ordering parts from digikey.com.
terry filter will need the following 4 parts:
1K 100 watt: digikey # FVT100-1.0K-ND correct value, but is wirewound. will its inductiveness affect the performance? will this handle the high voltage?
10Mohm .5 watt self explanitory
1800 volt MOV: digikey# P7227-ND does this look right?
.0033uf 1600v: digikey# P10501-ND this has a 1600v dc rating but no AC rating. will this work with AC in terry filter?
now for my MMC the cheapest caps i found here:
Cornell-Dubilier CDE 942C20P15K-F has a 2000 volt DC rating AC rating is usually lower than dc for capacitors . from what ive gathered these are the cap of choice for Tesla coils. tesla coils work on AC. will these still work? i need 8.6 nF with over 22kv(peak) rating. i could put 17 in series for 34kv and 8.824 nF
thank you for verifying my parts before i order.
the first link is dead. here is a pic of the schematic.for those that dont know, the terry filter is used to protect the neon sign transformer from damage from high frequency/high voltage from going back into it. i chose this because of its good history from other users.
I didn;t look at your parts closely, but I did notice the missing safety gap. Newark has some to 7.5 KV. You can probably put them in series, I have used 1000 V gaps before.
https://www.newark.com/jsp/search/b...ch&Ntt=gas+discharge&Ntx=mode+matchallpartial
This thing will probably have to be built using teflon or ceramic standoffs.
Those sorts of resistors generally can be used, but I would mount the mounting things on ceramic standoffs as well. Fiberglas makes a nice substate to make the base out of. Use Locktite 222 if you use screws and crimp terminals.
I would try to ascertain the voltage rating of the resistors by looking on their website and/or calling the manufacturer and then create a series combination of the voltage ratings. Generally, the longer the resistor the higher the ratings.
I've works on stuff that had a 15 kV, 1 Amp shunt regulator and 100 kV at 0.1 A power supplies. I would also create a safety as best as you can. e.g. Locked door, safety switches, a power switch that uses a key etc.
Teflon turret terminals https://www.newark.com/jsp/search/b...ions=false&ref=globalsearch&_requestid=351098 might also be used to put yur MOV's together.
Pay attention to distances and the dialectic strength: https://en.wikipedia.org/wiki/Dielectric_strength of the materials and air.
I didn't comment specifically on your parts. Maybe later today.
Get 2 ferite toroid about 1.5" ID wind each with 40 turns of #14 insulated house wire. Put a choke coil on each HV output terminal of your neon. You don't need the terry filter. 60 Hz will pass through the choke but the high frequency high voltage will not come back.
The mmc caps works great be sure to buy the correct caps and over voltage rate it a minimum of 40% above your transformer voltage.
Build a variable speed vacuum fan RQ spark gap, (VSVFRQSG) with a variac speed control. This thing is amazing you can dial in the correct fan speed for maximum arc length. Move your primary coil tap to find the best location for your top load. If you change your top load you must retune the primary.
https://i67.photobucket.com/albums/h292/mikeweaver/gap3.jpg
https://i67.photobucket.com/albums/h292/mikeweaver/gap4.jpg
https://i67.photobucket.com/albums/h292/mikeweaver/gaps5.jpg
https://i67.photobucket.com/albums/h292/mikeweaver/gap2.jpg
https://i67.photobucket.com/albums/h292/mikeweaver/gap1.jpg
You also need a variac on the input of your neon. This is extremely helpful when tuning the circuit for maximum output. Turn the voltage down so the output at the secondary is only about 1 inch long sparks. Next turn the fan speed of the spark gap you will notice the 1" output spark get longer and short as the fan speed changes. Find the best fan speed for max output then turn up the voltage on the neon.
Be sure to put a strike rail around the outer edge of the primary about 2" above the primary. Connect the strike rail to ground. If any HV arcs try to strike the primary they will hit the strike rail this protects your neon from HV. Look at the strike rail in the TC on the right side of the LAST PHOTO. The strike rail is 1 turn of 1/4" copper tubing the ends are "NOT" connected together they need to be about 1/2" from touching.
Here are some pics of some of my TCs. My 10" TC makes 12 foot arcs around the 3 ft sphear it produces a 27 ft circle is sparks in my back yard.
