Help required about Pspice
all4here
hello,
i am new User of Pspice.so i have a problem, when i am going to Trace the
output of the circuit.
i mean i don't know that which function is use for Frequency or Group delay
and i also can not capable to investigate the graph....
so i need a Book and any helping material , which they have all information
about Trace function and graph investigation...
thankx
thankx.......
but i need little bit more information
Here are a couple of links to get you started:
I think this one will probably help you the most, so maybe you should check this one first:
https://www.electro-tech-online.com/custompdfs/2012/01/PSPICE.pdf
If that doesn't work, here are a couple of tutorials you can look over. See if there's anything there that can help:
https://www.electro-tech-online.com/custompdfs/2012/01/PSPICEWorkshop.pdf
http://www.ee.nmt.edu/~rison/ee321_fall02/Tutorial.html
Good luck!
Regards,
Der Strom
thankx.......
The first link has a table of contents. You can look for the category in which your problem would reside, and go to that part of the pdf. I'm sure you'll find the information you need.
Regards
