Help regarding msp430f5438
Neerajneo
I am making a small project using msp430f5438 micro-controller and a L.C.D interface. But I am little confused how to burn the micro-controller as I am planning to buy a msp430f5438 experiment board but that is too costly for me. If anybody can assist me how to burn my 100 pin msp430f5438. And I am little confused about the experiment board that do it has any pins for interfacing such things or it is just a burner circuit. Please help me
ClydeCrashKop
Most Helpful Member
From: https://www.olimex.com/Products/MSP430/Starter/MSP430-5438-STK/resources/MSP430-5438STK-REV-B.pdf
BOARD FEATURES
CPU: MSP430F5438 mixed signal microcontroller
LCD NOKIA 3310 black/white 84x48 pixels
JTAG connector
JTAG Power_In and Power_Out jumpers
Two extension connectors
UEXT connector
RS232 driver and connector
Power plug-in jack for 9V DC power supply
Voltage regulator +3.3V – VR1(3.3V)
2 status LEDs
Power on Led
Audio In
Audio Out
SD/MMC mini connector
USB device connector
Reset button
User joystick
PCB: FR-4, 1.5 mm (0,062"), solder mask, silkscreen component print
Dimensions: 100x 98mm ( 3.94x 3.85")
BOARD USE REQUIREMENTS
Cables:
The cable you will need depends on the programmer/debugger you use. If
you use MSP430-JTAG, you will need LPT cable, if you use MSP430-JTAG-TINY or
MSP-JTAG-ISO, you will need 1.8m A-B USB cable, if you use MSP430-JTAG-RF,
you can connect it to the USB port of your computer, or via USB cable type A –
female.
Hardware:
Programmer/Debugger – one of our Programmers – MSP430-JTAG,
MSP430-JTAG-TINY
, MSP430-JTAG-ISO, or MSP430-JTAG-RF.
Software:
MSP430 KickStart software.
It looks like you get a lot for $56.00 https://www.digikey.com/product-search/en?mpart=MSP430-5438STK&vendor=1188
But you need the $75.40 programmer and software.
https://www.digikey.com/product-detail/en/MSP430-JTAG-TINY-V2/1188-1079-ND/3471390
Neerajneo
BOARD FEATURES
JTAG connector
UEXT connector
2 status LEDs
Power on Led
Audio In
Audio Out
Reset button
User joystick
Cables:
female.
Hardware:
MSP430-JTAG-TINY
Software:
BOARD FEATURES
JTAG connector
UEXT connector
2 status LEDs
Power on Led
Audio In
Audio Out
Reset button
User joystick
Cables:
female.
Hardware:
MSP430-JTAG-TINY
Software:
Thanks for your reply your suggestion really reduced my cost of project. Can you please assist me whether IAR workbench software can be used to burn the micro-controller using USB. And I am little bit confuse that whether it has any pin for LCD and KEYBOARD interface???
EE World Online Articles
Loading
