Help programming error/bug ?
jeyes56
hello,
Please help me on my problem, i made a code for DS1307 with using MPLAB v8.50,
it should display/save time and date on the EEPROM, but its not working very well,
Please help me to debug my code..
the output is like this.
Here are the codes:
main.c
//Sample code for
//DS1307 RTC Interfacing with PIC16F877A
//Coded by punkky@gmail.com
//Compiler: mikroC 8.0.0
//http://picnote.blogspot.com
//05/01/2009
//Use with your own risk
#include<pic.h>
#include"i2c.h"
unsigned short read_ds1307(unsigned short address );
void write_ds1307(unsigned short address,unsigned short w_data);
unsigned short sec;
unsigned short minute;
unsigned short hour;
unsigned short day;
unsigned short date;
unsigned short month;
unsigned short year;
unsigned short data;
char time[9];
char ddate[11];
unsigned char BCD2UpperCh(unsigned char bcd);
unsigned char BCD2LowerCh(unsigned char bcd);
void write_eeprom(unsigned char adr, unsigned char d);
unsigned char read_eeprom(unsigned char adr);
void write_eeprom_string(unsigned char adr, unsigned char eeprom[]);
void main(){
//I2C_Init(100000); //DS1307 I2C is running at 100KHz
PORTB = 0;
TRISB = 0; // Configure PORTB as output
TRISC = 0xFF;
//Lcd_Init(&PORTB); // Initialize LCD connected to PORTB
//Lcd_Cmd(//Lcd_CLEAR); // Clear display
//Lcd_Cmd(//Lcd_CURSOR_OFF); // Turn cursor off
//Lcd_Out(1, 1, "TIME:");
//Lcd_Out(2, 1, "DATE:");
//Set Time
write_ds1307(0,0x80); //Reset second to 0 sec. and stop Oscillator
write_ds1307(1,0x10); //write min 27
write_ds1307(2,0x01); //write hour 14
write_ds1307(3,0x02); //write day of week 2:Monday
write_ds1307(4,0x05); // write date 17
write_ds1307(5,0x01); // write month 6 June
write_ds1307(6,0x09); // write year 8 --> 2008
write_ds1307(7,0x10); //SQWE output at 1 Hz
write_ds1307(0,0x00); //Reset second to 0 sec. and start Oscillator
for(int y=0;y<0x0F;y++){;}
while(1)
sec=read_ds1307(0); // read second
minute=read_ds1307(1); // read minute
hour=read_ds1307(2); // read hour
day=read_ds1307(3); // read day
date=read_ds1307(4); // read date
month=read_ds1307(5); // read month
year=read_ds1307(6); // read year
time[0] = BCD2UpperCh(hour);
time[1] = BCD2LowerCh(hour);
time[2] = ':';
time[3] = BCD2UpperCh(minute);
time[4] = BCD2LowerCh(minute);
time[5] = ':';
time[6] = BCD2UpperCh(sec);
time[7] = BCD2LowerCh(sec);
time[8] = '\0';
ddate[0] = BCD2UpperCh(date);
ddate[1] = BCD2LowerCh(date);
ddate[2] ='/';
ddate[3] = BCD2UpperCh(month);
ddate[4] = BCD2LowerCh(month);
ddate[5] ='/';
ddate[6] = '2';
ddate[7] = '0';
ddate[8] = BCD2UpperCh(year);
ddate[9] = BCD2LowerCh(year);
ddate[10] = '\0';
write_eeprom_string(0x00,time);
write_eeprom_string(0x40,ddate);
//Lcd_Out(1,6,time);
//Lcd_Out(2,6,ddate);
//Delay_ms(50);
for(int x=0;x<=0xFF;x++) {;}
unsigned short read_ds1307(unsigned short address)
i2c_Start();
i2c_WriteTo(0xd0); //address 0x68 followed by direction bit (0 for write, 1 for read) 0x68 followed by 0 --> 0xD0
i2c_WriteTo(address);
i2c_Restart();
i2c_WriteTo(0xd1); //0x68 followed by 1 --> 0xD1
data=i2c_read(0);
i2c_Stop();
return(data);
return ((bcd >> 4) + '0');
return ((bcd & 0x0F) + '0');
i2c_Start(); // issue I2C start signal
i2c_WriteTo(0xD0); // send byte via I2C (device address + W)
i2c_WriteTo(address); // send byte (address of DS1307 location)
i2c_WriteTo(w_data); // send data (data to be written)
i2c_Stop(); // issue I2C stop signal
{  EEADR=adr;
   RD=1; // set the read bit
   return(EEDATA);
{  EEADR = adr;
   EEDATA = d;
   WREN = 1;  // write enable
   EECON2 = 0x55; // protection sequence
   EECON2 = 0xaa;
   WR = 1;  // begin programming sequnce
   for(int x=0;x<0xFF;x++){;}   // delay
   WREN = 0;  // disable write enable
{	for(int x=0;x<13;x++)
	{	if(eeprom[x]!=0)
		{	write_eeprom(adr,eeprom[x]);
			adr=adr+1;
		else
			x=15;
i2c.c
#include	<htc.h>
#include 	"i2c.h"
 *	I2C functions for HI-TECH PIC C - master mode only
 * 	TIMING - see Philips document: THE I2C-BUS SPECIFICATION
 * 	Send stop condition
 * 	  - data low-high while clock high
void
i2c_Stop(void)
	/* don't assume SCL is high on entry */
	SDA_LOW();					/* ensure data is low first */
	SCL_HIGH();
	__delay_us(I2C_TM_DATA_SU);
	SCL_DIR = I2C_INPUT;		/* float clock high */
	__delay_us(I2C_TM_STOP_SU);
	SDA_HIGH();					/* the low->high data transistion */
	__delay_us(I2C_TM_BUS_FREE);	/* bus free time before next start */
	SDA_DIR = I2C_INPUT;		/* float data high */
	return;
 * 	Send (re)start condition
 * 	  - ensure data is high then issue a start condition
 * 	  - see also i2c_Start() macro
void
i2c_Restart(void)
	SCL_LOW();					/* ensure clock is low */
	SDA_HIGH();					/* ensure data is high */
	SCL_DIR = I2C_INPUT;		/* clock pulse high */
	__delay_us(I2C_TM_SCL_HIGH);
	SDA_LOW();					/* the high->low transition */
	__delay_us(I2C_TM_START_HD);
	return;
 * 	Send a byte to the slave
 * 	  - returns true on error
unsigned char
i2c_SendByte(unsigned char byte)
	signed char i;
	for(i=7; i>=0; i--)
		SCL_LOW();					/* drive clock low */
		/* data hold time = 0, send data now */
        SDA_DIR = ((byte>>i)&0x01);
        if ((byte>>i)&0x01) {		/* bit to send */
			SDA_HIGH();
        }else {
			SDA_LOW();
		if(i2c_WaitForSCL())		/* wait for clock release */
			return TRUE;			/* bus error */
		__delay_us(I2C_TM_SCL_HIGH);	/* clock high time */
	return FALSE;
 * 	send an address and data direction to the slave
 * 	  - 7-bit address (lsb ignored)
 * 	  - direction (FALSE = write )
unsigned char
i2c_SendAddress(unsigned char address, unsigned char rw)
	return i2c_SendByte(address | (rw?1:0));
 * 	Check for an acknowledge
 * 	  - returns ack or ~ack, or ERROR if a bus error
signed char
i2c_ReadAcknowledge(void)
	unsigned char ack;
	SCL_LOW();						/* make clock is low */
	SDA_DIR = I2C_INPUT;			/* disable data line - listen for ack */
	__delay_us(I2C_TM_SCL_TO_DATA);	/* SCL low to data out valid */
	ack = SDA;						/* read the acknowledge */
	/* wait for slave to release clock line after processing byte */
		return I2C_ERROR;
	return ack;
 * 	Read a byte from the slave
 * 	  - returns the byte, or I2C_ERROR if a bus error
int
i2c_ReadByte(void)
	unsigned char i;
	unsigned char byte = 0;
	for(i=0; i<8; i++)
		__delay_us(I2C_TM_SCL_LOW);	/* min clock low  period */
		SDA_DIR = I2C_INPUT;		/* release data line */
			return I2C_ERROR;
		byte = byte << 1;		/* read the next bit */
		byte |= SDA;
	return (int)byte;
 * 	Send an (~)acknowledge to the slave
 * 	  - status of I2C_LAST implies this is the last byte to be sent
void
i2c_SendAcknowledge(unsigned char status)
	SCL_LOW();
	if ( status & 0x01) {
		SDA_LOW();				/* drive line low -> more to come */
	}else {
		SDA_HIGH();
	return;
 * 	Send a byte to the slave and acknowledges the transfer
 * 	  - returns I2C_ERROR, ack or ~ack
signed char
i2c_PutByte(unsigned char data)
	if(i2c_SendByte(data))
		return I2C_ERROR;
	return i2c_ReadAcknowledge();	/* returns ack, ~ack */
 * 	Get a byte from the slave and acknowledges the transfer
 * 	  - returns true on I2C_ERROR or byte
int
i2c_GetByte(unsigned char more)
	int byte;
	if((byte = i2c_ReadByte()) == I2C_ERROR)
		return I2C_ERROR;
	i2c_SendAcknowledge(more);
	return byte;
 * 	Send an array of bytes to the slave and acknowledges the transfer
 * 	  - returns number of bytes not successfully transmitted
int
i2c_PutString(const unsigned char *str, unsigned char length)
	signed char error;
	while(length)
		if((error = i2c_PutByte(*str)) == I2C_ERROR)
			return -(int)length;					/* bus error */
		else
			if(error)
				return (int)length;					/* non acknowledge */
		str++;
		length--;
	return FALSE;									/* everything OK */
 * 	Reads number bytes from the slave, stores them at str and acknowledges the transfer
 * 	  - returns number of bytes not successfully read in
unsigned char
i2c_GetString(unsigned char *str, unsigned char number)
	int byte;
	while(number)
		if((byte = i2c_GetByte(number-1)) == I2C_ERROR)
			return number;								/* bus error */
		else
			*str = (unsigned char)byte;
		str++;
		number--;
 * 	Opens communication with a device at address. mode
 * 	indicates I2C_READ or I2C_WRITE.
 * 	  - returns TRUE if address is not acknowledged
unsigned char
i2c_Open(unsigned char address, unsigned char mode)
	i2c_Start();
	i2c_SendAddress(address, mode);
	if(i2c_ReadAcknowledge())
		return TRUE;
	return FALSE;
 * 	wait for the clock line to be released by slow slaves
 * 	  - returns TRUE if SCL was not released after the
 * 	    time out period.
 * 	  - returns FALSE if and when SCL released
unsigned char
i2c_WaitForSCL(void)
	/* SCL_DIR should be input here */
	if(!SCL)
		__delay_us(I2C_TM_SCL_TMO);
		/* if the clock is still low -> bus error */
		if(!SCL)
			return TRUE;
	return FALSE;
void
i2c_Free()
	unsigned char ucI;
	SDA_DIR=I2C_INPUT;
	for(ucI=0;ucI!=9;ucI++)
		SCL_HIGH();
		__delay_us(5);
		SCL_LOW();
		__delay_us(5);
unsigned char i2c_read(unsigned char ucAdr)
	unsigned char ucDat;
	if (i2c_ReadFrom(ucAdr)==0)
		ucDat=i2c_GetByte(I2C_MORE);
		i2c_Stop();
	return(ucDat);
i2c.h
#ifndef	_I2C_H_
#define _I2C_H_
 *	SDA (data) and SCL (clock) bits
 *	Special note!!!
 *	If the clock and data lines are in the same port, you will need
 *	to beware of the Read/Modify/Write issue in the PIC - since
 *	a bit set or clear on any one bit in a port will read and write
 *	back all other bits.
#ifndef _XTAL_FREQ
 // Unless specified elsewhere, 4MHz system frequency is assumed
 #define _XTAL_FREQ 4000000
#endif
/* Uncomment the next line to use the PIC's SSP Module*/
#define I2C_MODULE 1
#ifdef I2C_MODULE
/* I2C module uses PORT C */
#define SCL             RC3             /* clock on port C bit 2 */
#define SCL_DIR         TRISC3
#define SDA     RC4                     /* data on port C bit 1 */
#define SDA_DIR         TRISC4
#define I2CTRIS TRISC
#define MASTER_MODE     0B1011          /* I2C firmware controlled Master Mode (slave idle) */
#define SSPMode(val)   SSPCON &=0xF0; SSPCON|=(val & 0xf)
#else
/* Change port as required - defaults to port b */
#define	SCL		RB2		/* clock on port B bit 2 */
#define	SCL_DIR		TRISB2
#define SDA             RB1             /* data on port B bit 1 */
#define	SDA_DIR		TRISB1
#define I2CTRIS TRISB
#endif
#define M_SDA_INP	0x02
#define M_SDA_OUT   0xFD
#define M_SCL_INP   0x04
#define M_SCL_OUT	0xFB
#define I2C_INPUT	1		/* data direction input */
#define I2C_OUTPUT	0		/* data direction output */
#define I2C_READ	0x01		/* read bit used with address */
#define I2C_WRITE	0x00		/* write bit used with address */
#define FALSE		0
#define TRUE		!FALSE
#define I2C_ERROR	(-1)
#define I2C_LAST	FALSE		/* SendAck: no more bytes to send */
#define I2C_MORE	TRUE		/* SendAck: more bytes to send */
#define i2c_Start()		i2c_Restart()
#define i2c_WriteTo(address)	i2c_Open((address), I2C_WRITE)
#define i2c_ReadFrom(address)	i2c_Open((address), I2C_READ)
#ifdef I2C_MODULE
#define SCL_HIGH() SCL_DIR = I2C_INPUT
#define SCL_LOW()  SCL_DIR = I2C_OUTPUT
#define SDA_HIGH() SDA_DIR = I2C_INPUT
#define SDA_LOW()  SDA_DIR = I2C_OUTPUT
#else
#define SCL_HIGH() SCL = 1; SCL_DIR = I2C_OUTPUT
#define SCL_LOW()  SCL = 0; SCL_DIR = I2C_OUTPUT
#define SDA_HIGH() SDA = 1; SDA_DIR = I2C_OUTPUT
#define SDA_LOW()  SDA = 0; SDA_DIR = I2C_OUTPUT
#endif
 * Timings for the i2c bus. Times are rounded up to the nearest
 * micro second.
#define I2C_TM_BUS_FREE		5
#define	I2C_TM_START_SU		5
#define I2C_TM_START_HD		4
#define I2C_TM_SCL_LOW		5
#define	I2C_TM_SCL_HIGH		4
#define I2C_TM_DATA_SU		1
#define I2C_TM_DATA_HD          0
#define I2C_TM_SCL_TO_DATA	4	/* SCL low to data valid */
#define	I2C_TM_STOP_SU		4
#define I2C_TM_SCL_TMO		10	/* clock time out */
extern signed char	i2c_ReadAcknowledge(void);
extern unsigned char	i2c_SendAddress(unsigned char, unsigned char);
extern unsigned char	i2c_SendByte(unsigned char);
extern int		i2c_ReadByte(void);
extern void		i2c_Restart(void);
extern void		i2c_Stop(void);
extern void		i2c_SendAcknowledge(unsigned char);
extern signed char	i2c_PutByte(unsigned char);
extern int		i2c_GetByte(unsigned char);
extern unsigned char	i2c_Open(unsigned char, unsigned char);
extern unsigned char	i2c_GetString(unsigned char *, unsigned char);
extern int		i2c_PutString(const unsigned char *, unsigned char);
extern unsigned char	i2c_WaitForSCL(void);
extern void 		i2c_Free(void);
extern unsigned char	i2c_read(unsigned char);
#endif			/* _I2C_H_ */
Please help me guys.
Thanks in advance...
two compilers? mikro c and hitech?? please elaborate your problem. try changing the reistor type from analog to digital one.
Where do you get two compilers from... they are both for hitech...
As for the resistor... you are correct.. it has to be a digital pullup in ISIS.
this made me think.
yeah, its a bit confusing. i think he just copied some code from the blog site and then posted here.
