Help !PIC 16F887 Generating 50Hz PWM Frequency for DC Motor Speed Control
twinsratio
Hi there,
Is that possible to generate 50Hz PWM frequency with using 20MHz external crystal ?
From what I heard, with 20Mhz crystal frequency it couldn't create such low PWM frequency, it that correct ?
Is the any other method to create PWM 50Hz by using 20MHz external crystal?
Below is my current coding basically I'm using timer0 to interrupt 1 second for the counter to get the pulse/sec from my motor. As now, my task is to create a PWM frequency at 50Hz to control the speed of the motor for 25%,50% n 75% duty cycle.
How can I edit my code to achieve 50Hz PWM frequency ? I'm using PIC 16F887 MCU
#include <htc.h>
#include <stdlib.h>
#include <string.h>
__CONFIG( HS & WDTDIS & PWRTDIS & MCLRDIS & UNPROTECT & DUNPROTECT & BORDIS & IESODIS & FCMDIS & LVPDIS & DEBUGDIS & BORV21);
#define RS RE0
#define RW RE1
#define EN RE2
unsigned int reload=76;
unsigned int rpm;
//High speed Osc (> 4mhz)
unsigned long s, k, w, a, b, c, y;
//LCD instruction function
void instruction(char C)
PORTE = 0x04; //RS =1 , W/R = 0 , E = 0
PORTD = C;
PORTE = 0x00;
for (s=0;s<30;s++){}
// LCD display function
void lcd (char C)
PORTE = 0x05; //RS =1 , W/R = 0 , E = 1
PORTD = C;
PORTE = 0x01; //RS =0 , W/R = 0 , E = 1
PORTD = C;
for (s=0;s<5;s++){}
/* write a string of chars to the LCD */
// LCD lcdout function for character input
void lcdout (const char *C)
PORTE = 0x04;
while (*C)
lcd(*C++);
void out ()
unsigned long counter = b;
char output[12];
ltoa(output, counter, 10);
instruction(0x80);
lcdout("Pulse/sec:");
lcdout(output); //output
instruction (0xC0);
lcdout("RPM:");
lcdout(output);
void out2 ()
instruction(0x80);
lcdout("Pulse/sec:0 ");
instruction (0xC0);
lcdout("RPM:0 ");
// Main Function
void main(void)
OSCCON= 0b01101110;
TRISA = 0xFF; //set PORTA as Input
TRISD = 0x00; //Set PORTD as Output (Data)
TRISE = 0x00; //Set PORTE as Output (EN, R/W, RS)
TRISC = 0x00; //Set PORT C as Output
ANSEL = 0x00;
ANSELH = 0x00;
ADCON0 =0x00; //’disable ADC
CM1CON0 =0x00; //’disable COMPARATOR 1
CM2CON0 =0x00; //’disable COMPARATOR 2
T1CON =0x00; //’disable TIMER1
OPTION = 0x07;
T0IE = 1; // Enable Timer
GIE = 1; // Enable Global Interrupt
y=0; //Initial counter value=0
//rpm=((y*60)/(3*20)); //formula for rpm
//LCD Function
instruction(0x0C); //Display on/off & cursor HEX 08-0F (1st)
instruction(0x38); //Function Set HEX 20-3F
instruction(0x01); //Clear Display HEX 01 (last)
while(1)
if(w==0)
{ out2();
switch (T0IE==1)
case 1:
if((RA0==0)&&(RA1==0)){
for(s=0;s<35;s++){} ////////pulse..
y++;
out();
w=1;
break;
static void interrupt
isr(void)
if(reload==0){
b=y;
rpm=y;
T0IE = 0; // disable Timer
y=0;
w=0;
instruction(0x01);
T0IE = 1; // disable Timer
reload = 76;
reload--;
T0IF = 0; // Clear Timer Interrupt Flag
Thank you inadvance
Thank you,
You could use timer one preset to 2 and load offset setting with
TMR1 = 15626 which gives 50.09 hz
