Help..Opto-Refective switch
cdsumlin
Hi, and thanks in advance for any help. I am building a crank sensor to interface with my computer. The part I needed is obsolete, so I ordered the substitute part suggested. Unfortunately I missed something and the wireing from the "opto-reflective IC" is different. I need help putting this circuit together. I need a pulse output, neg or positive, as a reference. this is the original circuit and part.
the part I recieved, opd770tz is:
what type of circuit do i need to make this work.
Thanks again, and Merry Christmas.
I make it this change.
Does this help?
using a 330 ohm r3 works, but the rise/fall times may be slow, have to experiment now, thanks for your help.
Working from +5V, with the Emitter having a forward voltage drop of 1.8V, leaves only 3.2V across the 330R, so the emitter current is only 10mA.
Use a 150R emitter diode resistor, to give 21mA, this will increase the response/sensitivity.[ the emitter is rated upto 40mA]
Lets know how it goes..:)
