help me
Mr pico
hello guys :)
i'am new in microchip prgramming and i work with a pic16f877 and css (pcw compiler ide) i wrote a programme but when i compile it an error message show on screen "NOT ENOUGH RAM" then i tried to work with an external eeprom but i have no idea how to work with it. please if someone there have an idea in eeprom programming (i want to write a programme not a simple data in this eeprom)
please help me
thanks
You can't write programs in external EEPROM - you need to write your program more carefully, and not waste resources.
Presumably that message means you've ruj out of GPR's?, NOT program memory - are you using lots of varibles, particularly unneeded floating point ones?.
hello
i used many floats in this program and here the program see it and if u can help me please i have no much more time
#include "C:\RAPPORT PFE\pcf programme\clock.h"
#include <LCD.C>
#include<math.h>
#use i2c (master,sda=pin_c1,scl=pin_c0)
void main()
int retval,s1,s2;
int min,m1,m2;
int hr,h1,h2;
int day,d1,d2;
int mon,mo1,mo2,month;
int year;
int i,p=10;
int mv=0,data;
int h3,h4,m3,m4;
float bta,D,N,N1,N2,N3,t;
float R,G,H,L,B;
float Z ,U1,U2,U,VD,Vn,w;
float fajer,dhuhur,aser,maghreb,icha;
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_1);
setup_timer_1(T1_DISABLED);
setup_timer_2(T2_DISABLED,0,1);
lcd_init();
while(1)
data=input_b();
//*************************************- Menu -***********************************************
if(data==0x01)
mv=mv+1;
if(mv==4)
mv=1;
delay_ms(150);
if(mv==1)
lcd_gotoxy(1,1);
lcd_putc("Reveil ");
if (data==0x04 )
p=p+3;
if(p>13)
p=10;
lcd_gotoxy((p-2),2);
lcd_putc(" 00| ");
delay_ms(200);
if(data==0x02 && p==10 )
h3=h3+1;
if(h3==10 && h4<3)
h3=0;
h4=h4+1;
if ((h4==2) && (h3>3))
h4=0;
h3=0;
lcd_gotoxy((p-1),2);
lcd_putc(h4+48);
lcd_gotoxy((p ),2);
lcd_putc(h3+48);
delay_ms(200);
if(data==0x02 && p==13 )
m3=m3+1;
if(m3==10 && m4<6)
m3=0;
m4=m4+1;
if ((m4==5) && (m3>9))
m4=0;
m3=0;
lcd_putc(m4+48);
lcd_gotoxy((p ),2);
lcd_putc(m3+48);
delay_ms(200);
if(mv==2)
//********************************************- programme pcf -***************************************
i2c_start();
i2c_write(0xa0);
i2c_write(0x00);
i2c_write(0x00);
i2c_stop();
strt:
//********************************- SECONDES -*****************************
i2c_start();
i2c_write(0xa0);
i2c_write(0x02);
i2c_start();
i2c_write(0xa1);
retval=i2c_read(0);
i2c_stop();
if(retval>9)
{ retval=retval-6; }
if(retval>19)
if(retval>29)
if(retval>39)
if(retval>49)
s1=retval/10;
s2=retval%10;
lcd_gotoxy(1,1);
lcd_putc("Time: ");
lcd_gotoxy(13,1);
lcd_putc(s1+48);
lcd_gotoxy(14,1);
lcd_putc(s2+48);
//-********************************- MINUTES -*****************************
i2c_start();
i2c_write(0xa0);
i2c_write(0x03);
i2c_start();
i2c_write(0xa1);
min=i2c_read(0);
i2c_stop();
if(min>9)
{ min=min-6; }
if(min>19)
{ min=min-6; }
if(min>29)
{ min=min-6; }
if(min>39)
{ min=min-6; }
if(min>49)
{ min=min-6; }
m1=min/10;
m2=min%10;
lcd_gotoxy(10,1);
lcd_putc(m1+48);
lcd_gotoxy(11,1);
lcd_putc(m2+48);
lcd_gotoxy(12,1);
lcd_putc(":");
//-********************************- HEURES -*****************************
i2c_start();
i2c_write(0xa0);
i2c_write(0x04);
i2c_start();
i2c_write(0xa1);
hr=i2c_read(0);
i2c_stop();
if(hr>9)
{ hr=hr-6; }
if(hr>19)
{ hr=hr-6; }
h1=hr/10;
h2=hr%10;
lcd_gotoxy(9,1);
lcd_putc(":");
lcd_gotoxy(7,1);
lcd_putc(h1+48);
lcd_gotoxy(8,1);
lcd_putc(h2+48);
//-*******************************-Date -********************************
lcd_gotoxy(1,2);
lcd_putc("Date: ");
//-********************************- jours -*****************************
i2c_start();
i2c_write(0xa0);
i2c_write(0x05);
i2c_start();
i2c_write(0xa1);
day=i2c_read();
day=day & 0x1f;
i2c_stop();
if(day>9)
{ day=day-6; }
if(day>19)
{ day=day-6; }
if(day>29)
{ day=day-6; }
if(day>20)
{d1==2; }
d1=day/10;
d2=day%10;
lcd_gotoxy(7,2);
lcd_putc(d1+48);
lcd_gotoxy(8,2);
lcd_putc(d2+48);
//-********************************- mois -******************************
i2c_start();
i2c_write(0xa0);
i2c_write(0x06);
i2c_start();
i2c_write(0xa1);
mon=i2c_read(0);
i2c_stop();
month=(mon & 0x1f);
if(month>10)
{ month=month-6; }
mo1=month/10;
mo2=month%10;
lcd_gotoxy(9,2);
lcd_putc("/");
lcd_gotoxy(10,2);
lcd_putc(mo1+48);
lcd_gotoxy(11,2);
lcd_putc(mo2+48);
//-*********- alarme de reveil-*********//
if(h1==h4 && h2==h3 && m1==m4 && m2==m3)
output_b(0x08);
//-***********- calculate the day of the year -****************-//
N1 = floor( (275 * month / 9));
N2 = floor((month + 9) / 12);
N3 = (1 + floor((2008 - 4 * floor(2008 / 4) + 2) / 3));
N = ((N1 - (N2 * N3) ) + (day - 30));
bta=(((2*(0.001))*N)/360);//year angle
//-****-declinaison de soleil-**********-//
D=((180/(0.001))*(0.006918-(0.399912*cos(bta))+(0.070257*sin(bta))-(0.006758*cos(2*bta))+(0.000907*sin(2*bta))-(0.002697*cos(3*bta))+(0.001480*sin(3*bta))));
//-******equatiopn de temps en minutes -****-//
T=(229.18*(0.000075+(0.001868*cos(bta))-(0.032077*sin(bta))-(0.014615*cos(2*bta))-(0.040849*sin(2*bta))));
//-*******(R)=reference de longitude; (G)=degree de fajr et maghreb; (H)=altitude above sea -****-//
R=15;
G=18;
H=25;
L=34;
B=8;
Z=(12+((R-L)/15)-(T/60));
U1=(sin((-0.8333-0.0347*(H/abs(H))*(sqrt(abs(H)))*((0.001)/180))-sin(D*((0.001)/180))*sin(B*((0.001)/180))));
U2=(cos(D*((0.001)/180))*cos(B*((0.001)/180)));
U=((180/(15*(0.001)))*acos(U1/U2));
Vd=((180/0.015)*acos((-(sin(19.5*(0.001/180)))-(sin(D*(0.001/180)))*(sin(B*(0.001/180))))/
((cos(D*(0.001/180)))*(cos(B*(0.001/180))))));
Vn=((180/0.015)*acos((-(sin(17.5*(0.001/180)))-(sin(D*(0.001/180)))*(sin(B*(0.001/180))))/((cos(D*(0.001/180)))*(cos(B*(0.001/180))))));
W=((180/0.015)*acos((sin(atan(1/(1+tan(abs(B-D)*(0.001/180)))))-sin(D*(0.001/180))*sin(B*(0.001/180)))/((cos(D*(0.001/180)))*(cos(B*(0.001/180))))));
fajer=Z-Vd;
dhuhur=Z;
aser=Z+w;
maghreb=Z+U;
icha=Z+Vn;
delay_ms(200);
goto strt;
if u have any suggestion please help me
and thnk you
Yep, that's alot of floating point math. Perhaps an 18F series PIC will give you the space you need.
Looks like you're building a solar tracker or heliostat.
Why are you running out of time?
hello guys :)
yes i build some thing like solar traker and i have to finish it before january,6th. and about the floating point i puted just what i need no more no less and i have to work with 16f877 microchip it's the rules.
and please can someone help to convert the value of "Z"
(Z it's a time equation) to minutes i cant do it alone :confused: . and thanx again
Of course you don't need them all! (you are using 24 of them!) - apply a little thought! - for example N1, N2, and N3 are only used inside one small routine, you could easily reuse those elsewhere, saving 3 floats already!.
i will try it
and what can i do for the rest of program iam confused :confused: and stressed :eek: because the short time but thanx for your help man and there is an other problem i just found it it's in pcf program it cant display correctly the date
for example today it's 28 december but the pcf display 08 january can any one help in this part and thank you guys.
see u ;)
If you don't need all the precision you could try using integers as fixed point numbers.
