Hey all,
I found this forum searching Google. I read several post before I started my own thread. Let me explain my project:
I have a small semi-automated welding station which consist of a small benchtop lathe and tig welder.
This is the lathe I have, it has a 3/4 hp motor: **broken link removed**
This is the welding unit that I have: **broken link removed**
I have a mechanical gear reduction mechanisum on the motor to slow the lathe down but that didn't slow down the motor enough. So, I hook up a power supply to the lathe motor to slow it down even more.
The problems with this setup are: the speed of the motor changes slightly and the operator has to constantly time the rotation and adjust the power supply voltage to regulate the speed of the lathe to 6 r.p.m.
So we definitely need to change the speed controller to something more precise. But, we are also considering on changing the motor so that we can ensure this precision. What do you think I should do?
So our situation is this: We have a low RPM speed requirement. We do not apply any load to the rotating shaft. The only load on the motor is from the resistance of the gears, friction and the weight of the lathe head. So we don't need alot of torque or power.
Any help to get me rolling would be really appreciated.
