Help in VHDL cooding
mus3na
My first problems is:
Ok i am doing some VHDL code. right now i have 2 VHDL source which is functioning as it suppose. now i like to combine booth, but i dont want combine it in one source file. What i like to do is to create third source file, than when ever i need that function i just call it. for example:
1) ADDER.VHDL
2) MULTIPLIER.VHDL
3) TOP_SOURCE.VHDL
so in top_source.vhdl, if i need adder operation i just call adder.VHDL to perform the operation. if i not misunderstand it will used port mapping to transfer data to subprogram and from sub program. it like subroutine in C or any other programming language.
can somebody show me how to o this or provide me with an example or website that have the solution to the problems.
My second problems is:
how to crate behaviour to do set 1 operation first than followed by set 2 when set 1 program finished. if in C or any other language, instruction executed line by line. but in VHDL it being executed all at the same time. How can i crate a code let say will add 2 number first than subtract with something and all code written in same process under same behaviour. If cannot! what is the best way to do that.
I thank you in advance.
Thanks, i will search all my book for how to convert the code to be component. by the way! if you have a good example, please share it wth me.
for second, i thought there must be other ways to run from state machine! since i preaty weak at this, well, look like i have to faced it.
Component:
entity XX is
port(....);
end XX;
architecture XXX of XX is
End XXX;
Main Prog:
entity YY is
port(...
local_s1: out std_logic
end YY;
archtecture YYY of YY is
Component XX
port(..The same of the original...);
U1:XX
port map(... --map signals to loacl signals.
for ex:
sig1=>local_s1;
State Machine
type States is(Idle,st1,st2);
Signal CS:States;
begin
process(Clk,CS)
begin
if rising_edge(CLK) then
case cs is
when IDLE =>
cs<=ST1;
when ST1=>
cs<=st2;
when st2=>
cs<=IDLE;
when others=>
cs<=idle;
end case;
end if;
end process;
