Thanks Les - here's everything I've got. I appreciate all the help with this.
What it's from? An obscure transparency-making copy machine from the early 70's. I've posted about it here before - it's called a Thermofax, made by 3M. I've looked in multiple sources for a schematic, including this site and 3M directly, with no luck. I don't have the specific model number either, but it was from a run of 15 amp machines (most of the current pulled from the high-intensity heat lamp).
What function does the relay perform? My speculation is that it is a motor-starting relay, but I just don't know. It engages when the motor turns on to run the transparency through the rollers, which is tripped by a switch triggered by the paper entering the machine.
Is the motor AC or DC? It is almost definitely a DC motor, and the unit includes a power supply and smoothing capacitors. The smoothing capacitors have been replaced and the machine functioned normally for several weeks after replacement.
What kind of resistance measurements do you get across the lugs? 1 and 2 show about 22ohm. 3 and 6 are open.
Can you bench test any of the components? Sort of. I don't have a variable power supply, but I do have a 3a 13.7vdc supply. I tried running this across the coil of the relay and it
does click over after a few moments of receiving voltage directly from the PS. When engaged, however, the resistance across the NO and NC lugs don't change - I attribute this to the dead short in the relay since I mucked it up.
I thought you said it was chattering and arcing. Why doesn't the relay work anymore? I pulled a screw out of the cover that I should not have when removing the part from the machine, and that bungled things. I don't have high hopes for it ever going back together correctly. Honestly, I had hoped to just read the specs from the side of the housing and get a new one. No such luck...
Can you post more photos? Yes!
What if I ran a variable resistor between the connections on 3 and 6 and slowly increased the voltage to see what I see? Too dangerous?
Mike
