Help Decimal to hexadecimal
Why? mikrobasic you can write $D0!! Otherwise you would need a function
208 / 16 = 13,, 208 mod 16 = 0 then use a lookup table so you convert 13 to D
charneeded = lookup(0,1,2,3,4,5,6,7,8,9,A,B,C,D,E,F) , index
It depends what you mean as 208 is already D0.
However, if you mean that you want to convert to the ascii "D0" then something like,
    num = 208
    fir = num / 16
    sec = num - fir * 16
    fir = fir + 48
    sec = sec + 48
    If fir > 57 Then fir = fir + 7
    If sec > 57 Then sec = sec + 7
should do it.
Alternatively, you could also do something like,
    dat = "0123456789ABCDEF"
    fir = Mid(dat, num / 16 + 1, 1)
    sec = Mid(dat, num Mod 16 + 1, 1)
I'm not familiar with MicroBasic so the above is generic.
Edit, Ian beat me to it by seconds.
The above does binary to hexadecimal!!
If you mean something else then explain what you need better.
i have a 8 bit binary number i convert it to dec and show it on led dsplay - I have it. them i convert 8bit binary number to hexadecimal and show it on display.
