fastback86
I'm trying to build a circuit I found while searching on the internet and I'm having trouble writing a HEX file. I must say first that I not very experienced in programming, compiling, and microcontrollers but I can't figure out what step I'm missing. Here's the code I'm trying to compile:
I'm using a Velleman K8048 and PicProg2009 software with a 16F628A. When I take the assembly file and past the code into it to covert to a hex file I get a bunch of errors (see attached text file). It looks like things are undefined and it can't find the the include files. Anyone know what I'm doing wrong?
Thanks!
; 8DGTCACC.INC: 8 digits CA or CC 7-segments LED display
; using conditional assembly
;-------------------- keywords for conditional assembly -----------------
; uncomment only one among these two directives
#define useCAdisplay ; if using Common Anode 7-segment display
;#define useCCdisplay ; if using Common Cathode 7-segment display
; uncomment only one among these five directives
;#define PORTX 5 ; if using PORTA (full 8 bits, example: PIC16F628)
#define PORTX 6 ; if using PORTB (any 18 pins mid-range PICmicro)
;#define PORTX 7 ; if using PORTC (any 28 pins mid-range PICmicro)
;#define PORTX 8 ; if using PORTD (any 40 pins mid-range PICmicro)
;#define PORTX 9 ; if using PORTE (any 40 pins mid-range PICmicro)
; declare in the main file:
; numdgt ; .128, then .64, .32, .16, .8, .4, .2, .1
; rlfcnt ; .8, then .7, .6, .5, .4, .3, .2, .1
; affvis ; ratio display visible
; dgtvis ; digit currently displayed
; dgtDS7 ; digit #7 (left most digit)
; dgtDS6 ; digit #6
; dgtDS5 ; digit #5
; dgtDS4 ; digit #4
; dgtDS3 ; digit #3
; dgtDS2 ; digit #2
; dgtDS1 ; digit #1
; dgtDS0 ; digit #0 (right most digit)
; macro to prepare input parameters to "Disp" routine
DISPDGT macro posdgt, dgt
MOVLW posdgt
MOVWF rlfcnt
MOVF dgt, w
CALL Disp
endm
;config. RBx & CC as outputs, (if Common Cathode), then RBx=HIGH & CC=LOW
;Config. RBx & CA as outputs, (if Common Anode), then RBx=LOW & CA=HIGH
SEGx macro REGx, RBx, jump, configRB, dgtX
BTFSC dgtX, RBx
GOTO jump
#ifdef useCCdisplay
BTFSS REGx, RBx ; conditional assembly
#endif
#ifdef useCAdisplay
BTFSC REGx, RBx ; conditional assembly
#endif
GOTO jump
BSF STATUS, RP0 ; flip to bank1
MOVLW configRB
XORWF dgtX, w
MOVWF PORTX
BCF STATUS, RP0 ; go back to bank0
MOVLW configRB
#ifdef useCCdisplay
XORLW 0FFh ; complement W (conditional assembly)
#endif
MOVWF PORTX
MOVLW .128 ; internal delay = 0.5 ms (quartz 4 MHz)
ADDLW 0FFh ; W--
BTFSS STATUS, Z ; bit Z=1 (i.e. W = 0 ?)
GOTO $-2 ; loop = 4 * 128 = 512 us
endm
; Routine to display 8 digits
; (one digit at a time, segment by segment individually)
Display
MOVLW .15
MOVWF affvis
dispdgts
DISPDGT .8, dgtDS7
DISPDGT .7, dgtDS6
DISPDGT .6, dgtDS5
DISPDGT .5, dgtDS4
DISPDGT .4, dgtDS3
DISPDGT .3, dgtDS2
DISPDGT .2, dgtDS1
DISPDGT .1, dgtDS0
DECFSZ affvis, f
GOTO dispdgts
RETURN
; Common Cathode digit, light segment by segment
; Common Anode digit, light segment by segment
Disp
MOVWF dgtvis
MOVLW high Tab7seg
MOVWF PCLATH
MOVF dgtvis, w ; (dgtvis) -> W
CALL Tab7seg ; convert
MOVWF dgtvis ; (dgtvis) converted to 7 segments code
#ifdef useCAdisplay
COMF dgtvis, f ; conditional assembly (for Common Anode)
#endif
CLRF numdgt
BSF dgtvis, 7
BSF STATUS, C
rlfloop
RLF numdgt, f
RLF dgtvis, f
BTFSC STATUS, C
GOTO setBit0
BCF dgtvis, 0
GOTO rlfnext
setBit0
BSF dgtvis, 0
rlfnext
BCF STATUS, C
DECFSZ rlfcnt, f
GOTO rlfloop
DispsegA SEGx dgtvis,0,DispsegB,0FEh, numdgt ; Disp. dgtvis, bit0
DispsegB SEGx dgtvis,1,DispsegC,0FDh, numdgt ; Disp. dgtvis, bit1
DispsegC SEGx dgtvis,2,DispsegD,0FBh, numdgt ; Disp. dgtvis, bit2
DispsegD SEGx dgtvis,3,DispsegE,0F7h, numdgt ; Disp. dgtvis, bit3
DispsegE SEGx dgtvis,4,DispsegF,0EFh, numdgt ; Disp. dgtvis, bit4
DispsegF SEGx dgtvis,5,DispsegG,0DFh, numdgt ; Disp. dgtvis, bit5
DispsegG SEGx dgtvis,6,DispsegX,0BFh, numdgt ; Disp. dgtvis, bit6
DispsegX SEGx dgtvis,7,Dispoff, 07Fh, numdgt ; Disp. dgtvis, bit7
Dispoff
CLRF PORTX ; clear portX
RETURN
; 8DGTCNT.ASM: main file to test display file "8DGTCACC.INC"
list P = 16F628A
#include <p16f628a.inc>
__CONFIG _CP_OFF &_BODEN_OFF &_PWRTE_ON &_WDT_OFF &_LVP_OFF &_MCLRE_OFF &_INTRC_OSC_NOCLKOUT
;---------------------- DEFINE HARDWARE ---------------------------------------
#define BTN PORTA, 4 ; push button connected to RA4
;--------------------- DEFINE VARIABLES ---------------------------------------
CBLOCK 0x70 ; common RAM [16 bytes, 0x70 to 0x7F]
numdgt ; .128, puis .64, .32, .16, .8, .4, .2, .1
rlfcnt ; .8, puis .7, .6, .5, .4, .3, .2, .1
dgtDS6, dgtDS5, dgtDS4 ; digit #6, digit #5, digit #4
dgtDS3, dgtDS2, dgtDS1 ; digit #3, digit #2, digit #1
ENDC
; increment one digit from 0 to maxi-1 ; if maxi, then wrap to 0
INC1 macro digitX, maxi, jump
INCF digitX, f ; increment digitX
MOVLW maxi
XORWF digitX, w
BTFSS STATUS, Z ; digitX = maxi ?
GOTO jump ; no
CLRF digitX ; yes, then clear digitX
endm
ORG 0x00 ; reset vector
GOTO Start
; L.U.T. to convert a decimal value into the corresponding 7 segment code
Tab7seg
ADDWF PCL, f ; display 7 segments GFEDCBA
DT 3Fh, 06h, 5Bh, 4Fh, 66h, 6Dh, 7Dh, 07h, 7Fh, 6Fh
#include "8DGTCACC.INC"
Start
bsf STATUS, RP0 ; flip to Bank 1
bsf BTN ; config. BTN as input
bcf STATUS, RP0 ; back to Bank 0
clrf dgtDS7
clrf dgtDS6
clrf dgtDS5
clrf dgtDS4
clrf dgtDS3
clrf dgtDS2
clrf dgtDS1
clrf dgtDS0
tstBtn
btfsc BTN ; BTN pushed
goto majDisp ; no
IncDgts
INC1 dgtDS0, .10, majDisp
INC1 dgtDS1, .10, majDisp
INC1 dgtDS2, .10, majDisp
INC1 dgtDS3, .10, majDisp
INC1 dgtDS4, .10, majDisp
INC1 dgtDS5, .10, majDisp
INC1 dgtDS6, .10, majDisp
INC1 dgtDS7, .10, majDisp
majDisp
CALL Display
GOTO tstBtn
END
Thanks!
