Help! Combining / converting fast pulses into single pulse (refer posted image)
menirva
Can anyone give me some idea or circuit, how to take this output, and change it into a single pulse?
Thanx!
I read about the low-pass filter.. what i understand is, low-pass filter allow low-frequency signal to pass thru, but cut out the higher frequency signal.
But the thing that i'm trying to do is, as shown in the picture.
I'm trying to build a circuit that can do such things.. can somebody give some idea?
Hi Menirva,
If you use a retriggerable monostable multivibrator and you select
the RC-time slightly longer than the period of one incoming pulse
you'll get one output pulse which will be slightly longer than the
incoming pulse train.
on1aag.
Can i make out something from 555, resistors, capacitors, 74HC14? If can, i want to build from parts that are easy to find.
Its okay, i just found out about ' Missing Pulse Detector'.. also got things to do with the problem that i'm trying to solve.
If i have problem later, i'll come again. Thanks for the monostable multivibrator information.
