Heatshrink
shermaine
How do we calculate the shrunking size of the heatshrink based on the diameter of the heatshrink?
Let say the diameter of the heatshrink when flattened is 4.2cm. What should be the shrunking size when the shrink ratio is 2:1?
Please advise.
Thanks.
It would just be half the original size. you could always just shrink a small piece and measure it.
Please advise.
Thanks.
Your best bet is to get the data from the manufacturer.. I'm sure they have it somewhere. Next best thing would be to measure one (as best as you can)
If we assume that the circumference of the unshrunk tubing is twice the flattened dimension that you indicate - 4.2 cm x 2 = 8.4 cm AND it shrinks to 1/2 the original dimension (2:1 as you stated) then the shrunk circumference is 4.2 cm - making the diameter 4.2 cm divided pi or about 1.3 cm
My knowledge of plastics suggests that there is a lot of variability in the performance. As previously suggested, if it's critical it would be best to experiment. One way to do this might be to shrink some samples on to some 1.3 cm pieces of scrap - trying a few smaller to see how that works - and trying larger if 1.3 cm isn't working.
