HC11 convert BCD to binary
windozeuser
I have an array (4 byte) with each byte being a possible BCD digit 0 to 9
How can I convert this entire byte BCD array into a 16 bit binary number?
I'm treating the entire array as one number, so array+3 = thousands, array+2 = hundreds, array+1 = tens, array = units
Yeah I've been reading it over and over, I can't figure out how to write it for the HC11 in assembly tho
The problem is that that chip is over 25 years old (and based on the older 6800) and, I guess, no one here has used it. I did program the 6809 at one time but it's too long ago to remember.
; Set up the Pincode buffer to store the code the user enteres from keypad
  ORG 0 ; Store Pincode in RAM
Pincode   RMB   4   ; Pincode 4 byte buffer
*	<<< MAIN PROGRAM LOOP >>>
	ORG	PROG
START
	; Load the Pincode array with the value 1234, with each digit being in it's own byte of the array
  ldaa #1
  staa Pincode
  ldaa #2
  staa Pincode+1
  ldaa #3
  staa Pincode+2
  ldaa #4
  staa Pincode+3
*CONVERT BCD TO A the 16bit binary decimal NUMBER
BCDBIN
  clra
  clrb ; clears D
  std BINVAL ; Clear BINVAL
thousands
  tst Pincode
  beq hundrends
  addd #1000
  dec Pincode
  bne thousands
hundrends
  tst Pincode+1
  beq tens
  addd #100
  dec Pincode+1
  bne hundrends
tens
  tst Pincode+2
  beq processpin
  addd #10
  dec Pincode+2
  bne tens
processpin
; take care of units
  addd Pincode+3
  std BINVAL ; BINVAL now equal to 16bit binary equiv
	ldx BINVAL
	cpx SECRET
	beq SUCCESS
	swi		;end program
SUCCESS
	ldx	#msg11	;point X to  message ; Display you got the Pin correct!!!
	jsr	OUTSTRG	;output it
This is the code I took from my larger program, basically I am polling a 4x4 keypad and storing a 4 digit "Pin number" the user enters into an array. The problem is each digit is in a separate byte of the array, and I need to convert the entire array into the 16 bit BCD equivalent.
This converts 1234 into 0x08D2, which is wrong, it should be 0x02D2, I can't figure out whats wrong!
Any help would be greatly appreciated!
I can't see anything wrong with your code but I did notice that 1234 is 0x04D2.
I found the problem with the help of the trace command and selecting 0 for all values,
addd Pincode+3
This is adding the address to the D register rather than the value at the address, I tried doing intermediate #Pincode+3 but it's still loading the address instead
