2PAC Mafia
I now what I´m going to explain sounds very strange but it´s happening...
I have to repair a Hatteland monitor which I saw it had a problem at it´s DC/DC converter. It used a DC/DC:
Hercules 6 MAH 36 006, Input: 9-36V, Output: 12V
Datasheet: https://www.powerbox.com.au/media/specification_sheet/MAH 36.pdf
This was damaged. I removed it and I connect my power supply to 12V, the consumption was 0,7A and the monitor worked perfectly.
Then I bought a Datel UHE-12/2500-Q12-C to replace the original DC/DC.
Datasheet: https://power.murata.com/data/power/uhe12-30w.pdf
When I installed it I saw how monitor didn´t switch on and I heard a click-click-click... from the DC/DC. I had 12V output but monitor didn´t switch on. I connected the DC/DC to a bulb and I saw the bulb like on-off-on-off all the time so I supposed the DC/DC came to me already defective.
I bought a second one, this time a DC/DC Traco power TEN 30-2412WIN.
Datasheet: **broken link removed**
When I installed I had exactly the same behavieur, this time I didn´t leave connected more than a few seconds to avoid damage it. I connected a 12V 21W at its output and it worked supplying 24V at input 1A consumption.
If I connect 12V at the PCB output, where the DC/DC should be, everything works, monitor switch on. I also tested the filtering input at PCB, I get the 24V input at pins where DC/DC should be.
For some reason, the behavieur is like there is too much consumption when I connect the DC/DC, then it starts protecting itself, but it has no sense because I already tested the consumption is only 0,7A and DC/DC output supports up to 2,5A!!!
No idea what is happening on this stupid issue...
