ccurtis
Hi all. I have used the laser toner transfer technique with widely varying results, mostly not good. But, I came across this supplier that appears to have tackled the usual problems with the technique.
1. The transfer sheet: Is made of porous water soluble material, so after the toner is transfered you dunk the sheet and board into water and the paper dissolves. The laser printer also transfers toner to it better because it is not slick like other transfer "paper".
2. The toner is fused to the copper by a laminating machine, rather than a hand iron, taking the variability and errors out of that step.
3. An additional sheet (green sheet) is placed over the transfered toner and passed through the laminating machine again to fill the small holes in the not-exactly-opaque toner.
4. Etching is done with a sponge loaded with Ferric Chloride rather than using an etching tank. It's supposedly much faster that way, but I only just read about it.
This technique and materials supposedly makes very fine traces, something I was never able to achieve with the transfer process since the toner spreads when heated.
https://www.pcbfx.com/main_site/pages/start_here/overview.html
Your thoughts? Has anyone used this product?
