Half of GLCD stopped working
superbrew
Hello, I was working with my GLCD and half of it stopped working. I was changing some code to display different graphics on it, so I don't think I changed anything to affect the operation. I also tried creating a new project from scratch and I get the same behavior. When I use my ClearScreen() function i am able to turn all of the pixels on or off, but when I try to draw on half of the display, I get nothing. I have LEDs on the CS0 and CS1 and they do switch as they should for writing to the second half of the display. Is this a bad display, or did I inadvertently change something else? Thanks
Pommie
Most Helpful Member
If you can turn all pixels on and off then I suspect you have a software bug. Do you have an earlier backup you can try?
Sceadwian
Banned
Something changed either in hardware or software. Perhaps you accidentally reconfigured the GLCD for a different mode? I don't know anything about these devices but there should be some way to reset it back to factory settings, or make sure it's setup for the mode you need to be in.
superbrew
Sorry, thanks for the help. I accidentally changed the wrong TRIS bit when i added in the touch screen to my project. I just wanted to make sure that I was not searching in vain if this was a common failure of KS0108 controllers.
EE World Online Articles
Loading
