dknguyen said:Do you mind giving a link for the datasheets?
motion said:First of all, it is normal for ths shaft to remain stiff when the stepper motor is stopped. This is called the holding torque ot the motor. This is so for as long as the current continuously flows through the coils. This is how the motor and motor driver are designed to do. The motor may also heat-up because of resistance and magnetic core losses.
The high pitched is caused by the fluctuating current as the voltage is being chopped. I assume you followed the circuit sample from the datasheet. The frequency is chosen so that is supposed to be above the hearing frequency. However, probably because of poor layout of your prototype and/or interaction with the cable to the motor, the current flow may be modulated and so the frequency drops to hearing range.
Do you have any method to reduce or eliminate the sound and I using full step operation to drive my motor?
