Good Benchtop Power supply
hey101
Hey I was looking around for a decent bench top power supply. I bought a cheap 0-15v 2a one from ebay but it just blew up after its second use. I am new to buying them but I do want a decent one this time. My budget is close to $100 but I may go higher if I need to. I probably wont get one that can support 10a but I would love for it to. Even 5a will probably be sufficient. As to max voltage i would at least need 12v but I do not mind if it can support higher voltage. Analog meters are fine but digital is preferred if possible. What would you guys recommend for a decent bench top psu that would support some of these features?
I was actually just reading about that. It sounds like a good idea. I noticed it would give the standard 3.3v, 5v. and even 12v. Although I read somewhere that you could add some other stuff to it to allow it to be a variable voltage one incase you needed it but I have yet to find out the parts needed or the circuit required to do so. Any suggestions?
You may, if you're very lucky, find a really good quality second hand supply for $100 on ebay, at a market or garage sale etc, but it's a tall order if you want quality. There are loads of new cheap supplies on ebay etc for less than $100, but they are just that, cheap junk, and you would be well advised to stay clear of them. You could possibly build a supply yourself if you use good quality surplus or used parts and there are literally thousands of free designs available on the net to choose from, but I suspect that you will either run out of money, or enthusiasm before you complete the project. My advice is to keep saving your money and buy a good quality, well built and specified supply from a recognised manufacturer like Hameg, Agilent etc, either from a good equipment seller on ebay, or a local lab equipment specialist, it will last you a lifetime if you look after it, and more importantly, be reliable :)
I tend to agree, I have a bunch of supplies, but my 12 V one is a Fixed voltage power supply, SELECTABLE from 0-32 V, 10A. It's from Harrison Labs, which was bought by HP. I paid $15 some 35 years ago. Replaced 3 transistors because it was repaired improperly and only got the manual about a year ago. You have to change the transformer taps depending on voltage. I also have a +-(12-15 V) and +5 that was part of something. It does not like reverse voltage. It takes out the 723 regulator. Then i have a couple of 0-30 3A supplies. For fun, I "boxed" a ebay step-down regulator with both 5.5/2.1 and 5.5/2.5 inputs and has an adapt-a-plug output. It has LED meters and current limited. So, I can replace nearly any wall wart I have to with a working 12 V, 1A wall wart and this regulator.
No, the modifications needed to make it "variable" is only of academic interest. The ATX PSU is designed to give a fixed voltage - plenty of current at 5 volts and a decent amount in 12. One can only trim the 5 volts, the 12 volts follows suit.
