general operating system vs real time operating system?
Parth86
operating system that provide interface between hardware and application software like windows
operating system design for different uses
real time used for fast response time
real time operating system it has guaranteed to respond in certain time
1) timing
2)scheduling
3)kernel
4)priority
1)timing -
rtos - it is time deterministic
gp os - it is non time deterministic
2)scheduling
scheduling for os .......?
scheduling for rtos - rtos use time sharing architecture where each task assigned small slice of time to execute its instruction before switching to another task
3)kernel ues in both RTOS and general purpose OS
what is difference between both kernel ?
4)priority - os will run task with their priority
priority for general os - general os don't follow priority level strictly
RTOS follow the priority level strictlyv
Are you asking us or telling us?
Basically OK.
Scheduling can be context switching or time/slice. Think of the early Macintoshes.
For a RTOS, the biggest issue is determinism or guaranteed response to an event.
Basically OK.
scheduling for rtos and general operating system
how general os scheduling is different from rtos scheduling ?
I am having difficulty to understand some terms
kernel is not modular
kernel is not fault tolerant
kernel is not configurable
can any one explain little bit
modular - not one large chunk of code
fault tolerant - Remember the blue screen of death on early PC's. Not fault tolerant.
not configurable - I'd might rename this as not "easily configurable:. Early OS's you had to "generate". Adding a module meant re-linking the OS. Now OS's, are dynamic linked. e.g., You can add/remove services in Windows without re-linking a new OS.
thanks for help , do you know any another reason why os fail in real time operating system
