Hello all,
I'm using an LM2907 frequency to voltage converter to measure a frequency coming from some optical sensors. The only problem is that the lm2907 is a ground referenced chip so that it measures freq by zero crossings. and the optical sensors I am using output low (or off) of about .4v and high to whatever amplitude, currently set at 5. So my frequency to be measured basically looks like a square wave from .4 to 5v. The problem is it never goes to 0. Is there a simple way to shift the whole waveform down so some of it goes negative and crosses 0 for the lm2907? I was pulling out my old textbooks and was thinking maybe i could use some sort of opamp summing circuit as a step inbetween the sensor and FTV converter. Any help/suggestions would be appreciated.
thanks
bonanz
thanks
bonanz
