Hi!
I have a small radio receiver and also a small radio transmitter.
It used to work, but now doesn't but the reason is that it works on 88.5 MHz frequency, but some jerks made a radio station in the same requency, so the radio isn't clear anymore, so I would need to make transmitter at 88 MHz.
Here are 2 circuits: (don't mind the C and L numbers)
The first simply shows that if I close and open the switch I could make sound on the radio.
The second shows that if I change a smaller voltage then with a transistor I open a larger voltage that would be like a plug for the audio jack.
But I have seen that these circuit use more then one capacitor, even resistors but why?
Won't this work?
Also I only have few capacitors and it isn't variable, it says that it has 220 uF with 16V. Does farads change if I only use 3V (2x batteries)?
And I hope these two are suitable for making a coil the right size:
f = 1/ (2*Pi*sqrt(L*C))
L = 0.394 * (N*R)^2 / (9R + 10h) (in meters)
Won't this work?
