DigiTan
I tried building this FM voice transmitter yesterday and so far, I haven't gotten it to work at all. It's intended to work for the 88MHz-108MHz commercial radio band.
After my circuit failed the second time, I was suspicious of the hand-wound inductor in the tuning net with C5 and L2. I went to Fry's and replaced L2 with a 0.1uH coil that would supposedly target this band. This was able to create noise at certain frequencies but not a voice signal.
I also tested Q1 and Q2; and I tried two different electret mics. When I rebuild the circuit the third time, I played loud music into the microphone and watched the voltages across C4 and C3 with a voltmeter. I could not see any change in voltage; but there was an AC signal on the antenna.
Does anyone have advice for the type of circuit; or has anyone had trouble recreating this one in particular? If the tuning circuit is not at fault, where should I check next?
