the dude of dudes
I bought this:
My intention is to use it in my work trailer (5x10' cargo trailer, aluminum walls, steel roof, wood floor) to rebroadcast Sirius radio. I work outside, generally within 100' of my trailer and I wear a small MP3 player w/FM radio (keeps the neighbors happier if they cant hear my music 9hrs a day). Problem is I'm only getting a quality signal up to 40' from my trailer. The unit has a built in 55" length of wire for an antenna.
I can see two problems:
1) The portable radio uses the headphone wire as an antenna, probably not the best for what I am doing
2) The setup is inside a metal trailer which is probably interfering with the signal
Is it possible to improve my transmitting antenna's situation? I thought maybe if I wrapped it around a strip of metal and mounted it on the roof vertically. I'd like to know if it would significantly improve the signal before I drill a hole in the roof of the trailer! Is there anything I can do improve the portable radios antenna/headphone wire? The wire moves when I move, and the bulk of it is stuffed inside my coat pocket. I'd look quite silly strapping an antenna to my forehead, wouldn't I. The transmitter is quite small, and only runs on 5v DC, so I know I shouldn't expect much, but the product info claimed a 150ft range .
