Mason Burns
New to electronics design, computer tech needs a schematic based on the simple TDA7000 ic
to continuously scan through the frequencies! I have the TDA7000s, and YDA9088s but they
are surface mounts. I can get most older ICs from a supplier in China so I'll take
suggestions. I just need it as simple as possible. I have TDA2822s for amps, but I can
get what is needed.
I just need an fm scanner to scan thru the frequencies and not lock on a station without
having to be reset to continue scanning. And output thru an earphone and speaker. Also, I
do not want to mute the scanning.
Certain things I need:
1) Scan at 200ms
2) Scan 88mHz - 108mHz and loop
3) Ability to hear the "white noise" as it's scanning
4) Not lock on any frequency
Thanks!
get what is needed.
1) Scan at 200ms
Thanks!
