Fluid coil spec help
Chip_er
Hi all, I've injoyed reading all I can in this fourm. But now I have to ask a question. I'm working on a mig welder. It has a gas valve that is controled by an electical coil. The coil and valve does work, my question is the volt amp? (AC 24V 50-60HZ 11VA). Can this coil only handle 11amps, or does it draw 11amps. The transformer has many taps, but none of which states 11amps. My biggest concern is not to fry this coil!
Thanks in advance!
Richard
The coil is rated for 24v AC (50/60hz), so it wants 24volts connecting to it to open the gas valve.
Volt-Amps (VA) is the product of volts and current.
Your coil will take about 0.46 amps from a 24v supply.
24volts x 0.46amps = 11VA
So, just connect it to 24v and it will be fine.
(The above assumes an AC 50/60hz supply, a DC supply will give a larger current).
