I have a switched-capacitor filter and an ADC chip. The switched cap filter uses a clock signal to set the cutoff frequency. The datasheet says:
"When using the MAX7401/MAX7405 for anti-aliasing or
post-DAC filtering, synchronize the DAC and the filter
clocks. If the clocks are not synchronized, beat frequencies
may alias into the passband."
I'm not sure what this means though...since the ADC clock is working at 4MHz and the filter clock is only working at 50khz. I'm not sure if it matters in this case because the only thing I know about synching clocks are clock distribution chips out there which seems excessive since those are for large systems.
